ArcGIS Pro - Symbology Tab How to turn off <all other values>
In ArcGIS Desktop 10, in the symbology for a layer in the map, for the "<all other values>", there is a check box that can be unchecked so that the "<all other values>" do not display in the map, see the following snapshot,
However, in ArcGIS Pro 2.1.3, For the "<all other values>" , there is no checkbox to turn off their display in the map, and on the right click menu, the "Remove" menu entry is grayed out, see the following snapshot:
Is there a way in ArcGIS to turn off the display of the "<all other values>" in the map, similar to how they can be turned off in ArcGIS Desktop 10?
It is there... you just have to find the toggle off option
Talk about simplifying the software.
My Rules...
Left click
Right click
Double click
If they don't work... you are clicking on the wrong thing
First lecture material for GIS courses
Dan,
Thank you for detailing out the steps needed to turn off the "all other values". I just missed it when I was trying to find it.
Chris
Dan's rules are spot on If you right-click on <all other values> you can just remove it.
I went back and read your original question. You're on 2.1.3.
This was updated in 2.2.
Funny that my 2.1.3 looks different. But thanks for this post - it helped me "find" the check-uncheck option in my install.
