ArcGIS Pro - Model Builder Help
3985
12
03-24-2020 08:56 PM
RickeyFight
So below is what I was asked to calculate. I thought summarize within would cut it but it will not.
This needs to happen for all 6000+ buildings in my city.
Drew Flater
Thanks!
DanPatterson_Retired
The submodel requirement
Iterators—ArcGIS Pro | Documentation
EDIT
Did you now remove the 2 iterator issue from your original question??
RickeyFight
Dan Patterson‌  Yes I did   I have a second iterator but I am having issues with the whole thing not just the iterator part so I removed it from the question.
RickeyFight
This is what I have so far I keep getting caught on calculate field.
pretty sketchy examples for calculate field in modelbuilder
Examples of using ModelBuilder utilities—Tools | Documentation
If using pro, there is the warning about significant changes to it
ModelBuilder: migration to ArcGIS Pro—ArcGIS Pro | Documentation
I dont use modelbuilder... maybe Curtis Price‌ will be of some help
RickeyFight
Dan Patterson
Thanks I will look at those. I think the hard part is that it is joining a field before calculate field.  I have to put in the parameters before the model gets run
curtvprice
This is quite a puzzle. Where are you doing the summarize to total up the scores?
RickeyFight
I have not gotten to that yet I am just trying to get part of the model working.
I might have found a work around.  I am going to make a near table. run the y= 124.8 e^(-0.05x) equation then sum all of them. After that I will multiply by the structure score.  This should just bypass the whole model.  I will post here if it does.
Near table.
curtvprice
That was my solution!
curtvprice
Darn I didn't realize, you can do this in one run!  That is a lot less complicated.
Though I tried this with polygons and it uses actual boundaries, not centroids. So neighbors have a distance of zero. So, depending on how you want to count neighbor distance, you may want to convert the polys to centroid points and run the Generate Near Table on the points.
