ArcGIS Pro 3.4.2: Exporting a layout containing imagery as PDF results in missing imagery,
4003
12
05-03-2025 06:47 AM
JamalNUMAN
Legendary Contributor
In the screenshot below, I exported a layout containing imagery as a PDF. The PDF was successfully generated; however, the imagery is missing from the output.
What could be causing this issue?
The imagery is attached
Jamal Numan
DanPatterson
MVP Esteemed Contributor
exported as what type of pdf and the options used might clarify your situation
... sort of retired...
JamalNUMAN
Which option do I need to change in order to export it correctly?
Jamal Numan
Faiez
Hi!
I just tested, it worked for me.
(view in My Videos)
JamalNUMAN
Which version is this—3.4.2?
If your time allows, could you please try using my imagery?
Jamal Numan
Faiez
Ok, ArcGIS Pro 3.4.3.
Faiez
If you have another image, please send it .
JamalNUMAN
I've reattached it in this post. The image file has a .img extension.
Jamal Numan
Faiez
The image has a PCS, and I changed the Map GCS to PCS, in order to match the image PCS, but it produced en empty PDF. I think there is a problem with the image, but I will check again.
JamalNUMAN
Hi Faiez,
But in principle, why should the failure to display the imagery in the PDF be a coordinate system issue? Isn’t the PDF supposed to simply display what physically appears in the layout?
I have reattached the image with its GCS before it was assigned a PCS.
Jamal Numan
