ArcGIS Pro 2.9: How to get the output of the batch shift stored in a folder?
549
01-06-2022 10:42 AM
JamalNUMAN
Legendary Contributor
Currently, the output of of the batch shift is compulsory stored in file geodatabase. How to get the output of the batch shift stored in a folder?
Jamal Numan
2 Solutions
ABishop
MVP Regular Contributor
This seems too obvious, but have you tried clicking on the folder button next to the current storage path and try redirecting it to a folder location of your choice?
Amanda Bishop, GISP
curtvprice
MVP Esteemed Contributor
@JamalNUMAN Have you tried setting your Analysis : Geoprocessing: Environment to your output folder? That should help, through you may need to revalidate each output to get the batch to fill in correctly.
Another approach in Pro: you could also export your batch to model builder and edit it.
Hope this helps!
ABishop
Amanda Bishop, GISP
curtvprice
Hope this helps!
JamalNUMAN
Thank you guys for the help.
Right the path can be directed to the target folder as below:
D:\B1\Shift_OutRaster_%Name%.tif
Jamal Numan
