We use a compound point style in our mapping - a circle with an arrow, then it's rotated by attributes. In previous versions, it's never been an issue to label the point - the labels sits right in the middle of the circle. Since 3.0 came out, it's like the label anchor has moved and can't be shifted so that the labels appear offset for some reason. I've tested this with other arrow-shaped symbols (which are not compound) and they all work correctly - the symbol appears in the centre. When we turn off Maplex, though, and use Standard, the issue corrects itself and the point label appears centred. The label geometry seems to show a left alignment which cannot be changed to centre.
Maplex is by far a superior labeling engine and we need it for other labels, but this symbol is an important part of our output and it adds so much extra work to deal with. Suggestions??
