Hello ArcGis Community!
I am annoyed, desperate, and in need of assistance!
I need help re-ordering a legend within my layout.
To be precise, I need to alter the "Districts" layer symbology class order in order to alter the order these values are printed within my legend.
Left Picture (Map Layer Screenshot)
Right Picture (Layout Legend Screenshot)
I can not seem to figure this out.
Additionally I need to sort the order of the districts using a custom sorting order, not alphabetical
I have tried altering the drawing order of the symbology with no success?
Any help is SINCERELY appreciated.
Solved! Go to Solution.
If I understand you problem then it is very easy to fix. You should just be able to change the order of the layer names from the Symbology pane and these will be updated in the Legend.
So from your Symbology pane, click in the specific feature name under the "Value" subheading, then drag up or down.
Can you convert the legend to graphics?
Then you can order the legend any way you want.
Thanks for the response Rickey! I gave this method a shot.
While this method does allow the flexibility to manipulate the positions of the graphics in detail but I found that the response from Mervyn Lotter below was just a bit simpler to accomplish my goal!
Through this approach I
- grouped the text and patch together into more organized layers as to not lose their original spacing
- re ordered the new grouped layers
-adjusted the and alignment properties accordingly to match the original legend specs
Thank you again for your advice, all insight is valuable.
Future projects might require legends to be altered with similar levels of detail and I plan to use it accordingly if need be.
Thanks again!
Thank you so much for your response!
This method worked exactly as I needed it to!
I know I'm late to the party, but this is a lifesaver - thank you so much!
Does anyone know if it is possible to move <all other values> in the symbology order? It appears to be stuck at the bottom and I would like it to appear at the top of my legend.
