Hello everybody ! The masking tools with ArcGIS Pro are wonderful, but when we use labels with a masked layer, they remain displayed on the map. And we have to export them as annotations to get the result we need (and it doesn't facilitate our work).
So it could be useful to integrate the labels into the masking functions. Even if it's possible...
Hello, we just got into this issue.
Our issue is that the feature layer with the labels we want to use don't have a field that we can use for queries so the only option we have is masking. The layer we want to mask covers the whole area and we have another label-layer that is better in a certain area and for only that area we want only those labels.
It would be perfect if masking did not only hide the features but also the labels for those features. Using weights would be too much work because we have so many layers that are showing different labels att different scales (we're working on creating a new base map). We're using data that are updated each week so we can't clip or change the data.
Hey all!
I know I'm late to the party, but I wanted to share my work around.
I am making a map series for each watershed in a state as a very basic reference map for some planners. I want things like counties and watersheds labeled regardless of position relative to the index feature from the map series, but I only want highways and rivers labelled inside the watershed we are focusing on.
I have created my reference map, "Focus Map", which I then clip to the index feature in the map series extent properties.
I then create a duplicate map in the catalogue pane called "Background". This is similarly tied to a map series, and shares the extent of the initial focus map frame. In this map I remove all of the labels that I want removed in the external area.
So now I have two map frames on the layout, with the focus watershed laid perfectly on top of its background twin beneath it.
Some geographies are labeled twice (such as when a county has area inside and outside of the watershed), but cleaning these up is much easier than making label annotations for each of the feature's labels I want masked out (since I have very variable scales between watersheds).
Obviously I think masking labels should be a built-in feature, but this is a fun work around.
Just ran into this issue - another vote that it would be really helpful to have masking of labels as an option (and a default) when you mask a feature layer.
This is kind of ridiculous. I turn on masking to hide the rivers as they flow through waterbodies , and the labels are still drawing.
I could probably use feature weights in this particular case, but that doesn't work for all (or even most) cases. What happens when I place something in the lake that I want to label, but I've turned the feature weight up enough that the label doesn't draw?
Please make labels beholden to masking rules.
Curiously, this still does not work as expected in ArcGIS Pro 3.6.1.
I have applied masking to the layers showing street names and house numbers. And adjusted the Label Weight Ranking as suggesties a few years ago as one of the first comments by @WendyHarrison in 2021.
What am I doing wrong here?
Are they true feature labels or annotation? If annotation then you should be able to mask them like any other layer. If they are labels then I'm not sure why they aren't being blocked. Looks correct to me. Only suggestion is do you have the "Never remove" option enabled in that layers labelling properties?
Thank you @LindsayRaabe_FPCWA. Yes, I have only used labels. No annotations.
I did not check the 'never remove' option before. It is disabled (see the image below). Perhaps there is another setting that stands in the way of properly removing the labels. It is quite difficult to know which settings to set in which way, because there are so many. I will give it a go.
