Remove or displace overlapping chart labels
2585
03-17-2021 10:08 PM
Status: Open
LindsayRaabe_FPCWA
MVP Regular Contributor
When creating charts that display stacked values, I find that sometimes the stacked values are small enough to result in the label from 2 different segments overlapping each other (see below example). It would be good if the chart either hid the lesser value automatically, or offset the different values to show both without conflict (bottom example).
Solution 1 - Displaced labels
Solution 2 - Hidden Label
Whilst this isn't really an issue when purely analysing data, when displayed in a map layout for exporting and sharing, it's not very cartographically pretty.
4 Comments
JessicaJThompson
Yes! I and a colleague were just discussing this! As well as being able to change the placement of labels so that they are within the bar of a stacked bar, vs having the label of the data being in the bar "above" its data.
wayfaringrob
Agree with you...why do I even need the 0s on my chart? Not seeing an option to turn them off; they're drawn right on top of where the actual values are. Ridiculous that this was pointed out a year and a half ago and is still a problem in 3.0. If I took that long to fix things, I'd be fired.
apgis16
Is there a way to fix labels so they don't overlap?
JPrüssmann
The overlapping labels in a Pro stacked bar chart look terrible, I wish there was a way to set their position to the middle of the bar. The funny thing is that this is something that can be achieved in AGOL maps and ExpB, but not in Pro apparently
