It would be helpful if we could control the logic used for getting the records on the many side of joins.
For example, choose an ORDER BY field: Grab the related record with the latest date, or something like that. Specify ascending or descending order.
Even better, make it a user-defined ORDER BY sql clause, so that we can use specialized logic like:
Related: Choose if join will be 1:1 or 1:Many
I didn't even think to try your definition query. Any experience trying it with AGOL hosted Feature Layers? Or with setting the definition in a python script?
Sorry, no experience with either.
Edit: What kind of database is AGOL behind the scenes? PostgreSQL? If so, then the SQLite definition query I mentioned might work, since PostgreSQL seems to support the LIMIT clause, just like SQLite.
Thanks @JonathanNeal I'll make a note to try this out, but unfortunatley entering the "busy season" and not much time to R&D on this project.
My hope is that this idea gets some more traction and ESRI implements sooner rather than later, because it's a great idea and would be an awesome functionality in ArcGIS Pro!
@BrantCarman Does this help you at all?
Use a SQL expression inside a Python or Arcade field calculation?
Interestingly, SQL is an option when using the field calculator on a hosted feature service.
I don't use hosted feature services (is that the same thing as AGOL?), so I don't know if it applies or not.
For example, could you do a SQL field calculation in ArcGIS Online, and use some SQL logic like I mentioned above to "grab the most recent record from the join table using ObjectID descending order"?
FYI, another option that is supported on file geodatabases are views:
https://pro.arcgis.com/en/pro-app/latest/tool-reference/data-management/create-database-view.htm
@JonathanNeal I couldn't find a way to "control what related record is used" (such as get the latest inspection for each road) when using a FGDB database view, since FGDB SQL doesn't support correlated subqueries.
@Bud I group by the join Id and used an aggregate to choose my values of interest.
Select Name, max(Desc) as myD from JoinTable group by Name
There is a classic FGDB use case in this post: Selecting the most recent records based on unique values in another field.
I tried using your "group by in a database view" technique:
--My FGDB table is called: species_records.
--The FGDB view below will be called: latest_vw.
select t_species as v_species, max(t_date) as v_date from species_records group by t_species
The requirement is: Select the latest record for each species group. Include all fields from the original table.
When it comes to your group by/view technique, I don't know how to bring all the other fields into the query. In other words, I don't know how to link the original table to the group by view.
I've tried a number of different SQL techniques (see Joins based on multiple fields) and also a "view on a view" that work in a mobile geodatabase but don't work in a file geodatabase, due to various FGDB SQL bugs.
Any ideas?
@Bud (Untested) I didn't get to trying it yet but put comments on what I am hoping will happen.
SQL for reporting and analysis on file geodatabases—ArcGIS Pro | Documentation
select
SUBSTRING(max(CONCAT(EXTRACT(YEAR FROM t_date), EXTRACT(MONTH FROM t_date), EXTRACT(DAY FROM t_date), OBJECTID)), 10, 10) as LastUpdatedOID
-- Cast date as text in the format YYYYMMDD
-- Get Field of interest, OBJECTID in our case
-- Skip the first 10 characters
from
species_records
group by
t_species
This is what I came up with. It's a FGDB database view.
Select the greatest 1 per group, with ties:
select * from species_records inner join (select t_species, max(t_date) as t_date from species_records group by t_species) l on species_records.t_species = l.t_species and species_records.t_date = l.t_date
Or, select 1 per group, without ties:
select * from species_records s inner join ( select min(objectid) as objectid, min(t_unique_id) as t_unique_id, t_species, max(t_date) as t_date from (select * from species_records inner join (select t_species, max(t_date) as t_date from species_records group by t_species) l on species_records.t_species = l.t_species and species_records.t_date = l.t_date ) group by t_species ) l on s.t_unique_id = l.t_unique_id
Source: Selecting the most recent records based on unique values in another field
I couldn't find a way to do it in a SQL expression. Only in a database view.
Sample Excel data: https://community.esri.com/t5/arcgis-pro-ideas/fgdb-database-views-view-that-selects-from-an/idi-p/1...
I'm starting to wonder if my original subquery approach was flawed:
Oracle (FETCH):
roadinsptable.objectid IN ( SELECT objectid FROM roadinsptable r2 WHERE r2.asset_id = roadinsptable.asset_id ORDER BY date_ DESC, condition DESC FETCH FIRST ROW ONLY )
Reason:
In the join, Pro uses the subquery to pare down the entire query, not just pare down the join table. More info here: Add Join — Create independent definition query on join table (pre-filter)
