FGDB database view — View that selects from an existing view
1607
01-12-2024 07:39 PM
Status: Open
Bud
Esteemed Contributor
ArcGIS Pro 3.2.1; File Geodatabase:
It would help to be able to create a view on top of an existing view in a file geodatabase.
Currently, in simple cases like SELECT * FROM EXISTING_VIEW,  the resulting view has zero rows (incorrect). Whereas in all other geodatabase and database types, a view can select from an existing view without issue.
Use Case:
1. Organization. Break large queries into smaller, more manageable pieces.
2. Also, complex queries like greatest 1 per group (with ties).  See: Selecting the most recent records based on unique values in another field and my comment about FGDB view challenges.
For example, get the latest row per species group (with ties), and include all the fields from the original table. That can't be done in a single FGDB view due to various FGDB SQL limitations (update: see follow-up reply below). Instead, I want to use multiple stacked views.
  • A view that gets the latest row per group (but doesn't include the other fields from the original table):
    --latest_vw
    select t_species, max(t_date) as t_date from species_records group by t_species
  • And then a view on top of that view that takes the fields from the original table and joins to LATEST_VW. The join is based on multiple fields: T_SPECIES=T_SPECIES and T_DATE=T_DATE.
    --latest_with_other_fields_vw
    select species_records.*, latest_vw.* from species_records
    inner join latest_vw on species_records.t_species = latest_vw.t_species
    and species_records.t_date = latest_vw.t_date
  • That approach works in mobile and enterprise geodatabases but not in file geodatabases since "a view on a view" doesn't seem to be supported; the joined fields from LATEST_VW are completely null, which is incorrect.
If I could create a view on a view, then that would solve the greatest 1 per group (with ties) problem in FGDB SQL.
I've attached sample Excel data that can be loaded into a file geodatabase.
2 Comments
MarceloMarques
My 2 cents. Certain SQL operations are only available in a RDBMS (Oracle, SQL Server, PortgreSQL) because the SQL Engine behind the RDBMS that is quite complex. Certain SQL functions in a File Geodatabase might not be available and it will be difficult to implement that because of this reason. Therefore, the best aproach is to move the data from the File Geodatabase to an Enterprise Geodatabase, even Mobile Geodatabase will present some limitations as well, thus move the data to an Enterprise Database (Oracle, SQL Server, PostgreSQL). I hope this helps.
Bud
Update
For example, get the latest row per species group, and include all the fields from the original table. That can't be done in a single FGDB view due to various FGDB SQL limitations.
I realize now that is incorrect. It can be done in a single view: Selecting the most recent records based on unique values in another field.
--species_records_latest_vw
select
from
    species_records
inner join
    (select
        t_species,
    from
        species_records
    group by
        t_species) l
    on species_records.t_species = l.t_species
       and species_records.t_date = l.t_date
But this idea is still valid. It would still help to create a view on a view.
