ArcGIS Pro 3.1.1
In the Diagnostic Monitor —> Log tab:
I can right-click the logs —> Copy selected:
When I paste the copied values into Excel, the data looks like this:
The log values are squished into a single column as <tags>.
It would be better if the data was formatted as a table, similar to how it looks in the Diagnostic Monitor Log tab:
That would facilitate tabular analysis of the log data.
Could the Diagnostic Monitor logs be enhanced so that the data gets copied as a table, not as tags?
As a last resort, the following workaround might be useful. It's pretty involved; I wouldn't want to do it very often.
1. Copy the logs as described in the original idea. Paste into Excel.
2. Add a header to the logs column: LOG_TAGS.
3. Select all values. Create an Excel table from the data (CTRL+T).
Option #1 - Use a SQL query in a database (go to step #4 below).
Option #2 - Use Power Query in Excel (go to the next comment in this post).
4. Create an additional Excel table column: ID. Populate with sequential numbers.
Reason for field: I figure it might be unwise to rely on the OBJECTID field as a sequential ID field.
5. The Excel table should look like this:
6. Save the Excel spreadsheet as Logs.xlsx.
7. In ArcGIS Pro, create a new mobile geodatabase called LOGS.geodatabase.
8. Use the Excel to Table GP tool to import the spreadsheet to the mobile GDB as a table.
9. Run the following SQL query using a SQL client like DBeaver.
WITH cte AS ( --Related Oracle post: https://stackoverflow.com/questions/76024662/fill-in-rows-per-group-for-pivoting
select sum(case when log_tags like '<Event%' then 1 else 0 end) over (order by id) group_id, --https://stackoverflow.com/a/76021834/5576771
case
when substr(log_tags,1,13) = '<Event time="' then 'col_1'
when substr(log_tags,1, 9) = 'Database:' then 'col_2'
when substr(log_tags,1,10) = ' SQL:' then 'col_3'
when substr(log_tags,1,16) = ' Number of ' then 'col_4'
when substr(log_tags,1, 8) = '</Event>' then 'col_5'
else 'col_6' --Sometimes the values in cols 2-4 are different from what I'm querying for above. Col_6 is a catch-all for any unexpected values.
--However, col_6 will only grab the first unexpected value it comes across; all others will be ignored. I haven't found a better way to do it.
end as type,
log_tags --substr(log_tags,1,100)
from logs
where log_tags is not null)
select group_id,
max(case when type = 'col_1' then log_tags end) col_1,
max(case when type = 'col_2' then log_tags end) col_2,
max(case when type = 'col_3' then trim(log_tags) end) col_3,
max(case when type = 'col_4' then trim(log_tags) end) col_4,
max(case when type = 'col_5' then log_tags end) col_5,
max(case when type = 'col_6' then trim(log_tags) end) col_6
from cte
group by group_id
order by group_id9. The resultset of the SQL query in DBeaver looks like this:
That's the desired result.
We can use that data to do tabular analysis on the logs when troubleshooting issues. We'd likely need to parse values from the columns to make the data useful.
Notes:
A. Be aware that not all logs/rows are structured the same way. Some logs have SQL queries in them like the ones shown in the above screenshots.
But other logs are different:
That makes it difficult to query the tag data using SQL. Cases/columns 2-4 work well most of the time. But not all of the time. That's where case/column 6 comes in. But it has limitations too.
case
when substr(log_tags,1,34) = ' Number of features returned:' then 'col_4'
end as type,
B. I tried skipping the Excel step and just pasting the log data from the Diagnostic Monitor right into an empty mobile geodatabase table. However, that seemed buggy. Sometimes the data would paste as expected. Other times, it seemed to omit or rearrange some rows. I didn't spend much time trying to find the root cause. I just played it safe and used Excel as an intermediate step instead.
C. The SQL query uses generic SQL. I've only tested it in SQLite (mobile GDB) and Oracle. But it should work in other DBs too.
10. Create a TAG_START_END column in the Excel table:
=IF( LEFT([@[LOG_TAGS]],6)="<Event","start", IF(LEFT([@[LOG_TAGS]],7)="</Event","end",""))
11. Create a TYPE column in the Excel table (see the CASE expression in the SQL query above for a more readable version):
=IF(LEFT([@[LOG_TAGS]],12)="<Event time=","col_1",
IF(LEFT([@[LOG_TAGS]],9)="Database:","col_2",
IF(LEFT([@[LOG_TAGS]],10)=" SQL:","col_3",
IF(LEFT([@[LOG_TAGS]],34)=" Number of features returned:","col_4",
IF(LEFT([@[LOG_TAGS]],8)="</Event>","col_5",
IF([@[LOG_TAGS]]<>"","col_6",""
))))))12. Create an Excel Power Query:
Click a cell in the Excel table —> Data tab in ribbon —> From Table/Range.
13. Click a cell to deselect any selected columns.
Home tab —> Remove Rows —> Remove Blank Rows.
14. Trim the preceding spaces in the LOG_TAGS column:
Right-click the LOG_TAGS column —> Transform —> Trim.
15. Create a Group column in the Power Query that groups the tags using a common ID (needed for pivoting later).
In the Power Query —> Advanced Editor window, replace the existing M-code with the following M-code:
let
Source = Excel.CurrentWorkbook(){[Name="Table"]}[Content],
#"Changed Type" = Table.TransformColumnTypes(Source,{{"LOG_TAGS", type text}, {"TYPE", type text}, {"TAG_START_END", type text}}),
#"Removed Blank Rows" = Table.SelectRows(#"Changed Type", each not List.IsEmpty(List.RemoveMatchingItems(Record.FieldValues(_), {"", null}))),
#"TrimSpaces" = Table.TransformColumns(#"Removed Blank Rows",{{"LOG_TAGS", Text.Trim, type text}}),
Lines = Table.ToRecords(TrimSpaces),
Result = List.Accumulate(Lines, [table={}, group=0, seq=0],
(state, current) => if Text.StartsWith(current[LOG_TAGS],"<Event")
then let g = state[group]+1, s = 1 in
[ table= state[table] & {[group=g,seq=s] & current},
group=g, seq=s]
else let g = state[group], s = state[seq]+1 in
group=g, seq=s] ),
Table1 = Result[table],
Table2 = Table.FromRecords(Table1)
in
Table2Result:
A Group column has been successfully created.
16. In the Power Query, remove these fields:
17. Pivot the data:
Click OK.
18. The Power Query should now look like this:
19. Click "Close & Load".
20. The resulting Excel worksheet should look like this:
21. I manually added column C to prevent the values in B from spilling over into the blanks in column C.
C = ' [there's a space after the single-quote]
22. Complete.
With certain log data, I get an error from Power Query:
Evaluation resulted in stack overflow and cannot continue.
I haven't figured out what specific log data causes that issue.
It might have something to do with the "Result" Power Query step:
Here's a specialized SQL query that extracts information about query logs that returned at least 1 row:
--https://community.esri.com/t5/arcgis-pro-questions/mobile-gdb-database-view-case-expression-value/td-p/1279170
WITH cte AS (
select sum(case when log_tags like '<Event%' then 1 else 0 end) over (order by objectid) group_id,
case
else 'col_6'
end as type,
log_tags
from logs
select
substr(xml, instr(xml, 'elapsed=') + length('elapsed=') + 1) + 0 as elapsed, --https://stackoverflow.com/a/76078619/5576771
row_count+0 as row_count,
lower(query) || '; --Excel rownum: ' || (row_number() over() + 2) as query
--lower(query) as query
from (
select group_id,
max(case when type = 'col_1' then log_tags end) xml,
--max(case when type = 'col_2' then log_tags end) col_2,
max(case when type = 'col_3' then substr(trim(log_tags), 6) end) query,
max(case when type = 'col_4' then substr(trim(log_tags),30) end) row_count
--max(case when type = 'col_5' then log_tags end) col_5,
--max(case when type = 'col_6' then trim(log_tags) end) col_6
from cte
group by group_id
order by group_id
where
row_count+0 > 1
Related: Open table with join (sorted) — Logs show redundant queries sent to DB
A Python script for parsing the XML tags and inserting into a table (untested):
https://sqlite.org/forum/forumpost/cedad1130c0e828f
