ArcGIS Pro Tools Comparison by ArcGIS Pro Levels
https://pro.arcgis.com/en/pro-app/latest/tool-reference/main/arcgis-pro-tool-reference.htm
Thank you, this is exactly what we were looking for 🎉
Thank you so much!
I've added Google and Duck Duck Go columns the xls. Each takes uses the Tool name to search with. Google shows list of results for pro.arcgis.com domain. DDG opens the first result directly, which is usually but not guaranteed to be that specific tool's documentation page.
The google result formula is
=HYPERLINK(CONCAT("https://www.google.com/search?q=", [@Tool], "+site:pro.arcgis.com", "&udm=14"), "google")
duck duck go:
=HYPERLINK(CONCAT("https://duckduckgo.com/?q=!ducky+", [@Tool], "&site:pro.arcgis.com"), "ddg ")
Sources:
Postscript: I discovered this sheet thanks to using the Feedback button on the main website to complain about not enough info in ArcGIS Pro license levels. The response from @TimOrmsby of the ArcGIS Pro Documentation Team was exceptional. Tim clearly took the time to read, understand, and then thoughtfully compose a substantive response. This level of consideration in customer service is rare in my experience. Kudos to Tim and the team which gives him the leeway to do this.
PPS: Andrei of X-Tools Pro actually beat Tim to the punch, but as I was processing emails most recent first I missed it on initial read. He points out there is also the detailed ArcMap functionality matrix, with latest findable being a pdf for 10.7: https://www.esri.com/content/dam/esrisites/en-us/media/pdf/product/desktop/arcgis-10.7-desktop-arcma...
@EdwinRoaam I correct in assuming a blank in Basic or Standard columns means "No, not available" ?
Note: with the new Professional Plus User Type, additional Extensions will be included with ArcGIS Pro Advanced
ArcGIS 3D Analyst
ArcGIS Data Reviewer
ArcGIS Geostatistical Analyst
ArcGIS Image Analyst
ArcGIS LocateXT
ArcGIS Network Analyst
ArcGIS Publisher
ArcGIS Spatial Analyst
ArcGIS Workflow Manager
2023 and 2024 ArcGIS User Type Comparison Matrix (esri.com)
@EdwinRoa Interested in a new run of the script for Pro 3.3!
