ArcGIS Pro Functionality Levels (Geoprocessing Tool)
9132
11
04-25-2024 09:06 AM
Comments
SimonSchütte_ct
MVP Regular Contributor
Thank you, this is exactly what we were looking for 🎉
MattWilkie1
Thank you so much!
I've added  Google and Duck Duck Go columns the xls. Each takes uses the Tool name to search with. Google shows list of results for pro.arcgis.com domain. DDG opens the first result directly, which is usually but not guaranteed to be that specific tool's documentation page.
The google result formula is
=HYPERLINK(CONCAT("https://www.google.com/search?q=", [@Tool], "+site:pro.arcgis.com", "&udm=14"), "google")
duck duck go:
=HYPERLINK(CONCAT("https://duckduckgo.com/?q=!ducky+", [@Tool], "&site:pro.arcgis.com"), "ddg ")
Sources:
Postscript: I discovered this sheet thanks to using the Feedback button on the main website to complain about not enough info in ArcGIS Pro license levels. The response from @TimOrmsby of the ArcGIS Pro Documentation Team was exceptional. Tim clearly took the time to read, understand, and then thoughtfully compose a substantive response. This level of consideration in customer service is rare in my experience. Kudos to Tim and the team which gives him the leeway to do this.
PPS: Andrei of X-Tools Pro actually beat Tim to the punch, but as I was processing emails most recent first I missed it on initial read. He points out there is also the detailed ArcMap functionality matrix, with latest findable being a pdf for 10.7: https://www.esri.com/content/dam/esrisites/en-us/media/pdf/product/desktop/arcgis-10.7-desktop-arcma...
MattWilkie1
@EdwinRoaam I correct in assuming a blank in Basic or Standard columns means "No, not available" ?
SimonSchütte_ct
ArcGIS Pro Advanced will include additional Extensions with the new Professional Plus User Type:
  • ArcGIS 3D Analyst
  • ArcGIS Data Reviewer
  • ArcGIS Geostatistical Analyst
  • ArcGIS Image Analyst
  • ArcGIS LocateXT
  • ArcGIS Network Analyst
  • ArcGIS Publisher
  • ArcGIS Spatial Analyst
  • ArcGIS Workflow Manager
    2023 and 2024 ArcGIS User Type Comparison Matrix (esri.com)
    Not included in Professional Plus are business specific extensions and additional software such as:
  • Data Interoperability
  • ArcGIS Reality for ArcGIS Pro
  • ArcGIS Location Referencing (ArcGIS Pipeline Referencing or ArcGIS Roads and Highways)
  • ArcGIS Airports
  • ArcGIS Aviation Charting
  • Business Analyst
  • ArcGIS Indoors Pro​
  • ArcGIS Indoors Maps​
  • ArcGIS IPS​
  • Production Mapping​
  • ArcGIS Maritime​
  • ArcGIS Bathymetry​
  • Defense Mapping
RubenBenne
Occasional Explorer
@EdwinRoa Interested in a new run of the script for Pro 3.3!
SimonSchütte_ct
Starting with ArcGIS Pro 3.3 the following tools are included in ArcGIS Pro Basic:
Add Attachments (Data Management)—ArcGIS Pro | Documentation
Annotate Selected Features (Cartography)—ArcGIS Pro | Documentation
Convert Spatial Statistics Popup Charts for Web Display (Spatial Statistics)—ArcGIS Pro | Documentat...
Create Relationship Class (Data Management)—ArcGIS Pro | Documentation
Disable Attachments (Data Management)—ArcGIS Pro | Documentation
Downgrade Attachments (Data Management)—ArcGIS Pro | Documentation
Enable Attachments (Data Management)—ArcGIS Pro | Documentation
Export XML Workspace Document (Data Management)—ArcGIS Pro | Documentation
Generate Attachment Match Table (Data Management)—ArcGIS Pro | Documentation
Import XML Workspace Document (Data Management)—ArcGIS Pro | Documentation
Migrate Relationship Class (Data Management)—ArcGIS Pro | Documentation
Remove Attachments (Data Management)—ArcGIS Pro | Documentation
Set Relationship Class Split Policy (Data Management)—ArcGIS Pro | Documentation
Table To Relationship Class (Data Management)—ArcGIS Pro | Documentation
Upgrade Attachments (Data Management)—ArcGIS Pro | Documentation
GeoTagged Photos To Points (Data Management)—ArcGIS Pro | Documentation
ArcGIS Pro 3.3 functionality that previously required Standard or was limited with Basic license:
Convert labels to annotation—ArcGIS Pro | Documentation
Match Photos To Rows By Time (Data Management)—ArcGIS Pro | Documentation
Tiled Labels To Annotation (Cartography)—ArcGIS Pro | Documentation
Update Annotation Reference Scale (Cartography)—ArcGIS Pro | Documentation
JoshuaClanton
Thank you for building these sheets! They've been extremely helpful for the new license restructure
HollyTorpey_LSA
Thank you! This is incredibly helpful. It's so hard to find this information when budgeting for licenses without looking up every individual tool your team might need. It's even harder to have to go back to the executive management team to request additional budget when you find out that the Professional licenses you purchased for most of the team don't include Overlay Toolset staples like Erase, Update, and Identity 😫. I wish we had found this sooner!
Speaking of which, does anyone know why the Erase tool is only available with the Professional Plus license but Pairwise Erase is included at every level?
SimonSchütte_ct
ArcGIS Pro 3.4 has 38 new toolsets (hope I did not miss any):
ToolBoxToolsetToolBasic (Creator User Type)Standard (Professional User Type)Advanced (Professional Plus User Type)
Data managementLayers and Table Views toolsetGenerate Definition Query From SelectionYesYesYes
3D AnalystExtraction toolsetExtract Rails From Point CloudRequires 3D AnalystRequires 3D AnalystRequires 3D Analyst
AllSourceConversion toolsetMilitary Raster To Mosaic Dataset YesYes
Business AnalystSuitability Analysis toolsetSet Target SiteRequires Business AnalystRequires Business AnalystRequires Business Analyst
Cartography toolboxCartographic Refinement toolsetCalculate Color Theorem Field YesYes
ConversionPoint Cloud (prev. LAS toolset)Mesh To LASRequires Spatial Analyst or 3D AnalystYesYes
Data managementAttribute Rules toolsetGenerate ID Attribute Rule YesYes
Data managementAttribute Rules toolsetGenerate Spatial Join Attribute Rule YesYes
Data managementAttribute Rules toolsetGenerate Symbol Rotation Attribute Rule YesYes
Data managementContingent Values toolsetGenerate Contingent ValuesYesYesYes
Data managementFields toolsetAlter FieldsYesYesYes
Data managementGeneral toolsetDelete MultipleYesYesYes
Data managementPackage/SceneLayer toolsetGenerate Level Of DetailYesYesYes
Data managementWorkspace toolsetEnable Editing Templates YesYes
GeoprocessingGeostatistical Analyst/Spatial Statistics toolboxDirectional TrendYesYesYes
GeoprocessingImage/Synthetic Aperture Radar toolsetApply CoregistrationRequires Image AnalystRequires Image AnalystRequires Image Analyst
GeoprocessingImage/Synthetic Aperture Radar toolsetCompute CoherenceRequires Image AnalystRequires Image AnalystRequires Image Analyst
GeoprocessingImage Analyst/Deep Learning toolsetDetect Control PointsRequires Image Analyst or ArcGIS Reality for ArcGIS ProRequires Image Analyst or ArcGIS Reality for ArcGIS ProRequires Image Analyst or ArcGIS Reality for ArcGIS Pro
IndoorsIndoors toolboxGenerate Floor Plan From Point Cloud  Requires 3D Analyst and ArcGIS Indoors Pro or ArcGIS Indoors Maps. Also requires Spatial Analyst or Image Analyst
IndoorsIndoors Network toolsetGenerate Indoor Network Features  Requires ArcGIS Indoors Pro or ArcGIS Indoors Maps
IndoorsIndoors Network toolsetImport Features To Indoor Dataset  Requires ArcGIS Indoors Pro or ArcGIS Indoors Maps
GeoprocessingLocation Referencing toolboxGenerate LRS Data ProductRequires ArcGIS Location Referencing (ArcGIS Pipeline Referencing or ArcGIS Roads and Highways)Requires ArcGIS Location Referencing (ArcGIS Pipeline Referencing or ArcGIS Roads and Highways)Requires ArcGIS Location Referencing (ArcGIS Pipeline Referencing or ArcGIS Roads and Highways)
GeoprocessingParcel toolboxFind Adjacent Parcel Points YesYes
GeoprocessingParcel toolboxFind Gaps And Overlaps YesYes
GeoprocessingReality Mapping toolboxDetect Control PointsRequires Image Analyst or ArcGIS Reality for ArcGIS ProRequires Image Analyst or ArcGIS Reality for ArcGIS ProRequires Image Analyst or ArcGIS Reality for ArcGIS Pro
Spatial AnalystSurface toolsetFeature Preserving SmoothingRequires Spatial AnalystRequires Spatial AnalystRequires Spatial Analyst
Spatial AnalystSurface toolsetMultiscale Surface DifferenceRequires Spatial AnalystRequires Spatial AnalystRequires Spatial Analyst
Spatial AnalystSurface toolsetMultiscale Surface PercentileRequires Spatial AnalystRequires Spatial AnalystRequires Spatial Analyst
Spatial AnalystZonal toolsetZonal CharacterizationRequires Spatial AnalystRequires Spatial AnalystRequires Spatial Analyst
Spatial StatisticsAssessing Sensitivity toolsetAssess Sensitivity to Attribute UncertaintyYesYesYes
Spatial StatisticsModeling Spatial Relationships toolsetBivariate Spatial Association (Lee's L)YesYesYes
Spatial StatisticsSpatial Component Utilities (Moran Eigenvectors)Compare Neighborhood ConceptualizationsYesYesYes
Spatial StatisticsSpatial Component Utilities (Moran Eigenvectors)Create Spatial Component Explanatory VariablesYesYesYes
Spatial StatisticsSpatial Component Utilities (Moran Eigenvectors)Decompose Spatial Structure (Moran Eigenvectors)YesYesYes
Spatial StatisticsMeasuring Geographic Distributions toolsetDirectional TrendYesYesYes
Spatial StatisticsSpatial Component Utilities (Moran Eigenvectors)Filter Spatial Autocorrelation From FieldYesYesYes
Topographic Production toolboxCartography/Features toolsetGenerate Isogonic Lines Requires Production Mapping and Spatial AnalystRequires Production Mapping and Spatial Analyst
SimonSchütte_ct
At ArcGIS Pro 3.4, LocateXT was licensed as an extension. At ArcGIS Pro 3.5, it is no longer an extension. The same LocateXT functionality is available directly in ArcGIS Pro with a Standard or Advanced license.
Release notes for ArcGIS Pro 3.5—ArcGIS Pro | Documentation
kll
Occasional Explorer
Hi @EdwinRoa This is so great, is there an ArcGIS Pro tool reference in version 3.5 as well? Thanks a lot 🙂
Cheers Linda
Version history
Last update:
‎04-15-2025 02:57 PM
Updated by:
Contributors
