ArcGIS Pro Functionality Levels (Geoprocessing Tool)
16178
13
04-25-2024 09:06 AM
Comments
SimonSchütte_ct
MVP Regular Contributor
Thank you, this is exactly what we were looking for 🎉
MattWilkie1
Thank you so much!
I've added  Google and Duck Duck Go columns the xls. Each takes uses the Tool name to search with. Google shows list of results for pro.arcgis.com domain. DDG opens the first result directly, which is usually but not guaranteed to be that specific tool's documentation page.
The google result formula is
=HYPERLINK(CONCAT("https://www.google.com/search?q=", [@Tool], "+site:pro.arcgis.com", "&udm=14"), "google")
duck duck go:
=HYPERLINK(CONCAT("https://duckduckgo.com/?q=!ducky+", [@Tool], "&site:pro.arcgis.com"), "ddg ")
Sources:
Postscript: I discovered this sheet thanks to using the Feedback button on the main website to complain about not enough info in ArcGIS Pro license levels. The response from @TimOrmsby of the ArcGIS Pro Documentation Team was exceptional. Tim clearly took the time to read, understand, and then thoughtfully compose a substantive response. This level of consideration in customer service is rare in my experience. Kudos to Tim and the team which gives him the leeway to do this.
PPS: Andrei of X-Tools Pro actually beat Tim to the punch, but as I was processing emails most recent first I missed it on initial read. He points out there is also the detailed ArcMap functionality matrix, with latest findable being a pdf for 10.7: https://www.esri.com/content/dam/esrisites/en-us/media/pdf/product/desktop/arcgis-10.7-desktop-arcma...
MattWilkie1
@EdwinRoaam I correct in assuming a blank in Basic or Standard columns means "No, not available" ?
SimonSchütte_ct
ArcGIS Pro Advanced will include additional Extensions with the new Professional Plus User Type:
  • ArcGIS 3D Analyst
  • ArcGIS Data Reviewer
  • ArcGIS Geostatistical Analyst
  • ArcGIS Image Analyst
  • ArcGIS LocateXT
  • ArcGIS Network Analyst
  • ArcGIS Publisher
  • ArcGIS Spatial Analyst
  • ArcGIS Workflow Manager
    2023 and 2024 ArcGIS User Type Comparison Matrix (esri.com)
    Not included in Professional Plus are business specific extensions and additional software such as:
  • Data Interoperability
  • ArcGIS Reality for ArcGIS Pro
  • ArcGIS Location Referencing (ArcGIS Pipeline Referencing or ArcGIS Roads and Highways)
  • ArcGIS Airports
  • ArcGIS Aviation Charting
  • Business Analyst
  • ArcGIS Indoors Pro​
  • ArcGIS Indoors Maps​
  • ArcGIS IPS​
  • Production Mapping​
  • ArcGIS Maritime​
  • ArcGIS Bathymetry​
  • Defense Mapping
RubenBenne
Occasional Explorer
@EdwinRoa Interested in a new run of the script for Pro 3.3!
SimonSchütte_ct
Starting with ArcGIS Pro 3.3 the following tools are included in ArcGIS Pro Basic:
Add Attachments (Data Management)—ArcGIS Pro | Documentation
Annotate Selected Features (Cartography)—ArcGIS Pro | Documentation
Convert Spatial Statistics Popup Charts for Web Display (Spatial Statistics)—ArcGIS Pro | Documentat...
Create Relationship Class (Data Management)—ArcGIS Pro | Documentation
Disable Attachments (Data Management)—ArcGIS Pro | Documentation
Downgrade Attachments (Data Management)—ArcGIS Pro | Documentation
Enable Attachments (Data Management)—ArcGIS Pro | Documentation
Export XML Workspace Document (Data Management)—ArcGIS Pro | Documentation
Generate Attachment Match Table (Data Management)—ArcGIS Pro | Documentation
Import XML Workspace Document (Data Management)—ArcGIS Pro | Documentation
Migrate Relationship Class (Data Management)—ArcGIS Pro | Documentation
Remove Attachments (Data Management)—ArcGIS Pro | Documentation
Set Relationship Class Split Policy (Data Management)—ArcGIS Pro | Documentation
Table To Relationship Class (Data Management)—ArcGIS Pro | Documentation
Upgrade Attachments (Data Management)—ArcGIS Pro | Documentation
GeoTagged Photos To Points (Data Management)—ArcGIS Pro | Documentation
ArcGIS Pro 3.3 functionality that previously required Standard or was limited with Basic license:
Convert labels to annotation—ArcGIS Pro | Documentation
Match Photos To Rows By Time (Data Management)—ArcGIS Pro | Documentation
Tiled Labels To Annotation (Cartography)—ArcGIS Pro | Documentation
Update Annotation Reference Scale (Cartography)—ArcGIS Pro | Documentation
JoshuaClanton
Thank you for building these sheets! They've been extremely helpful for the new license restructure
HollyTorpey_LSA
Thank you! This is incredibly helpful. It's so hard to find this information when budgeting for licenses without looking up every individual tool your team might need. It's even harder to have to go back to the executive management team to request additional budget when you find out that the Professional licenses you purchased for most of the team don't include Overlay Toolset staples like Erase, Update, and Identity 😫. I wish we had found this sooner!
Speaking of which, does anyone know why the Erase tool is only available with the Professional Plus license but Pairwise Erase is included at every level?
SimonSchütte_ct
ArcGIS Pro 3.4 has 38 new toolsets (hope I did not miss any):
ToolBoxToolsetToolBasic (Creator User Type)Standard (Professional User Type)Advanced (Professional Plus User Type)
Data managementLayers and Table Views toolsetGenerate Definition Query From SelectionYesYesYes
3D AnalystExtraction toolsetExtract Rails From Point CloudRequires 3D AnalystRequires 3D AnalystRequires 3D Analyst
AllSourceConversion toolsetMilitary Raster To Mosaic Dataset YesYes
Business AnalystSuitability Analysis toolsetSet Target SiteRequires Business AnalystRequires Business AnalystRequires Business Analyst
Cartography toolboxCartographic Refinement toolsetCalculate Color Theorem Field YesYes
ConversionPoint Cloud (prev. LAS toolset)Mesh To LASRequires Spatial Analyst or 3D AnalystYesYes
Data managementAttribute Rules toolsetGenerate ID Attribute Rule YesYes
Data managementAttribute Rules toolsetGenerate Spatial Join Attribute Rule YesYes
Data managementAttribute Rules toolsetGenerate Symbol Rotation Attribute Rule YesYes
Data managementContingent Values toolsetGenerate Contingent ValuesYesYesYes
Data managementFields toolsetAlter FieldsYesYesYes
Data managementGeneral toolsetDelete MultipleYesYesYes
Data managementPackage/SceneLayer toolsetGenerate Level Of DetailYesYesYes
Data managementWorkspace toolsetEnable Editing Templates YesYes
GeoprocessingGeostatistical Analyst/Spatial Statistics toolboxDirectional TrendYesYesYes
GeoprocessingImage/Synthetic Aperture Radar toolsetApply CoregistrationRequires Image AnalystRequires Image AnalystRequires Image Analyst
GeoprocessingImage/Synthetic Aperture Radar toolsetCompute CoherenceRequires Image AnalystRequires Image AnalystRequires Image Analyst
GeoprocessingImage Analyst/Deep Learning toolsetDetect Control PointsRequires Image Analyst or ArcGIS Reality for ArcGIS ProRequires Image Analyst or ArcGIS Reality for ArcGIS ProRequires Image Analyst or ArcGIS Reality for ArcGIS Pro
IndoorsIndoors toolboxGenerate Floor Plan From Point Cloud  Requires 3D Analyst and ArcGIS Indoors Pro or ArcGIS Indoors Maps. Also requires Spatial Analyst or Image Analyst
IndoorsIndoors Network toolsetGenerate Indoor Network Features  Requires ArcGIS Indoors Pro or ArcGIS Indoors Maps
IndoorsIndoors Network toolsetImport Features To Indoor Dataset  Requires ArcGIS Indoors Pro or ArcGIS Indoors Maps
GeoprocessingLocation Referencing toolboxGenerate LRS Data ProductRequires ArcGIS Location Referencing (ArcGIS Pipeline Referencing or ArcGIS Roads and Highways)Requires ArcGIS Location Referencing (ArcGIS Pipeline Referencing or ArcGIS Roads and Highways)Requires ArcGIS Location Referencing (ArcGIS Pipeline Referencing or ArcGIS Roads and Highways)
GeoprocessingParcel toolboxFind Adjacent Parcel Points YesYes
GeoprocessingParcel toolboxFind Gaps And Overlaps YesYes
GeoprocessingReality Mapping toolboxDetect Control PointsRequires Image Analyst or ArcGIS Reality for ArcGIS ProRequires Image Analyst or ArcGIS Reality for ArcGIS ProRequires Image Analyst or ArcGIS Reality for ArcGIS Pro
Spatial AnalystSurface toolsetFeature Preserving SmoothingRequires Spatial AnalystRequires Spatial AnalystRequires Spatial Analyst
Spatial AnalystSurface toolsetMultiscale Surface DifferenceRequires Spatial AnalystRequires Spatial AnalystRequires Spatial Analyst
Spatial AnalystSurface toolsetMultiscale Surface PercentileRequires Spatial AnalystRequires Spatial AnalystRequires Spatial Analyst
Spatial AnalystZonal toolsetZonal CharacterizationRequires Spatial AnalystRequires Spatial AnalystRequires Spatial Analyst
Spatial StatisticsAssessing Sensitivity toolsetAssess Sensitivity to Attribute UncertaintyYesYesYes
Spatial StatisticsModeling Spatial Relationships toolsetBivariate Spatial Association (Lee's L)YesYesYes
Spatial StatisticsSpatial Component Utilities (Moran Eigenvectors)Compare Neighborhood ConceptualizationsYesYesYes
Spatial StatisticsSpatial Component Utilities (Moran Eigenvectors)Create Spatial Component Explanatory VariablesYesYesYes
Spatial StatisticsSpatial Component Utilities (Moran Eigenvectors)Decompose Spatial Structure (Moran Eigenvectors)YesYesYes
Spatial StatisticsMeasuring Geographic Distributions toolsetDirectional TrendYesYesYes
Spatial StatisticsSpatial Component Utilities (Moran Eigenvectors)Filter Spatial Autocorrelation From FieldYesYesYes
Topographic Production toolboxCartography/Features toolsetGenerate Isogonic Lines Requires Production Mapping and Spatial AnalystRequires Production Mapping and Spatial Analyst
SimonSchütte_ct
At ArcGIS Pro 3.4, LocateXT was licensed as an extension. At ArcGIS Pro 3.5, it is no longer an extension. The same LocateXT functionality is available directly in ArcGIS Pro with a Standard or Advanced license.
Release notes for ArcGIS Pro 3.5—ArcGIS Pro | Documentation
kll
Occasional Explorer
Hi @EdwinRoa This is so great, is there an ArcGIS Pro tool reference in version 3.5 as well? Thanks a lot 🙂
Cheers Linda
VenkataKondepati
Honored Contributor
This is a useful clarification having clearly defined functionality levels for geoprocessing tools helps set expectations for users and makes documentation easier to follow. It’s especially helpful when tools behave differently across ArcGIS Pro license levels or extensions. Thanks for summarizing this in one place it will save a lot of confusion for users trying to understand why certain tools are available in some environments but not others.
– Venkat
SimonSchütte_ct
ArcGIS Pro 3.7
License Changes:
  • The ArcGIS Reality for ArcGIS Pro extension is no longer available with the Single Use license type. To license the ArcGIS Reality for ArcGIS Pro extension, you need the Named User license type with the Reality extension license.
  • Concurrent Use licenses are no longer supported
  • (If used) New Single Use licenses must be obtained. For more information, see Single Use License change for ArcGIS Products
License Changes to existing tools:
  • Evaluate Rules—The tool is now available when using branch versioning for named users with an ArcGIS Pro Basic license (included with the Creator user type) and the ArcGIS Advanced Editing user type extension. This applies only to Named User licenses in an ArcGIS Enterprise organization.
  • Validate Topology—The tool is now available when using branch versioning for named users with an ArcGIS Pro Basic license (included with the Creator user type) and the ArcGIS Advanced Editing user type extension. This applies only to Named User licenses in an ArcGIS Enterprise organization.
  • When using branch versioning, the following tools are now available to named users with an ArcGIS Pro Basic license (included with the Creator user type). This applies only to Named User licenses in ArcGIS Online and ArcGIS Enterprise organizations.
  • Reconcile Versions—The tool is now available when using branch versioning for named users with an ArcGIS Pro Basic license (included with the Creator user type) and the ArcGIS Advanced Editing user type extension. This applies only to Named User licenses in an ArcGIS Enterprise organization.
There are 50+ new tools available:
  • Create Terrain From BIM—Creates a terrain surface in an ArcGIS terrain dataset from a TIN surface in an AutoCAD Civil 3D file, or a surface in an Industry Foundation Classes (.ifc) file.
  • TIN To Multipatch—Converts a TIN dataset to a multipatch feature class.
  • Generate Customer Demographic Profile Report—Creates a report summarizing customer demographics based on an input point dataset.
  • Extract Scanned Lines—Generates polyline features from scanned images.
  • Extract Scanned Polygons—Generates polygon features from scanned images.
  • Convert Personal Geodatabase—Converts a legacy personal geodatabase (.mdb) or a Microsoft Access database (.mdb, .accdb) to a mobile geodatabase, file geodatabase, or XML workspace document.
  • To Parquet is a new toolset.
    • Export To Parquet—Exports simple data (points, lines, polygons, and nonspatial tables) from a shapefile, file geodatabase, mobile geodatabase, enterprise geodatabase, or database to an Apache Parquet file
  • Alter Coded Value Description—Updates the description value for an individual, existing coded value pair.
  • Alter Geometry Index Preference—Allows the owner of a feature class in SAP HANA to alter the setting on the spatial column that controls what type of spatial index is used for most spatial queries.
  • Export Layouts—Exports multiple layouts to a specified export format.
  • Alter Subtype—Alters the subtype name of an existing subtype code.
  • Extract Embedding To Fields—Extracts vector embeddings stored as binary large object (BLOB) fields into individual numeric fields in a new output feature class.
  • Find Similar Features Using Embeddings—Performs large-scale similarity search on location and image data by comparing their embedding representations.
  • Generate Embeddings Using AI Models—Generates semantic embeddings for geospatial data using foundation models.
  • Merge Embeddings—Merges embeddings from an input embeddings feature class into target polygons based on the area of overlap.
  • Predict Missing Values Using AI Model—Replaces missing values (nulls) with estimated feature values.
  • Split Match Narrative Into Fields—Splits match narrative results into multiple fields and appends them to a geocoded feature class.
  • Convert Video Metadata—Prepares a video metadata file for further processing in geospatial video workflows by field matching and converting unit types.
  • Extract Ocean Winds—Estimates wind direction and magnitude on the ocean surface.
  • Extract Spectra From Image—Extracts spectral signatures from input feature data using imagery to create an Esri Spectral Library (.esl) file.
  • Generate Video Metadata (Stationary)—Creates a geospatially enabled video file from a pre-recorded video without metadata.
  • Reduce Spectral Bands—Reduces the number of spectral bands in multiband imagery using Minimum Noise Fraction and Principal Components Analysis analytical methods.
  • Translate Pixels Using Deep Learning—Translates pixels in an image using deep learning model information. Examples of translations include increasing the pixel resolution and converting a grayscale image to a color image.
  • Generate Beacon Placement Plan—Creates an optimized plan of IPS beacon features to provide indoor BLE coverage with the fewest required beacons.
  • Create File Knowledge Graph—Creates a file knowledge graph in a folder and configures its parameters.
  • Copy Knowledge Graph Types—Copies the data model and data from one knowledge graph to another.
  • Export Knowledge Graph—Creates a service definition file of a knowledge graph.
  • Configure Utility Network Feature Classes—Configures the ArcGIS Utility Network Pipeline Line, Pipeline Device, and Pipeline Junction feature classes for use with a linear referencing system (LRS).
  • Export Voxel Isosurface—Exports one or more isosurfaces from a voxel layer, scene layer package, or netCDF file.
  • Update Fleet Routing Assignments—Updates the route assignments of all stops on the collection edges for the current selection to the indicated route.
  • Update Fleet Routing Results—Updates the route result metrics based on the current route name designations for stops. This operation can resequence stops within their route assignment.
  • Export Network Travel Modes—Exports a network dataset's travel modes to a JSON file.
  • Replace Network Travel Modes—Replaces a network dataset's travel modes with travel modes defined in a JSON file.
  • Adjust Raster to Stream—Modifies the cell values of an input surface raster at specified locations.
  • Generate Breach Lines—Creates a line that breaches the local impediment of water flow.
  • Generate Weighted Voronoi—Creates spatial influence zones from point features by assigning locations to sites based on distance along or distance modified by the site-specific weights.
  • Geodesic Flow Direction—Calculates geodesic flow direction from each cell to its downslope neighbors.
  • Multicriteria Overlay—Combines multiple rasters using a chosen overlay method with applied weights.
  • Raster to Weighted Points—Generates representative, value-proportional points from continuous surfaces, preserving spatial patterns and total magnitudes.
  • Surface Area Ratio—Calculates a surface area to planar area ratio for each cell of a raster surface.
  • Top Hat Transform—Detects spatial structures on a raster surface by calculating the top hat transforms.
  • Validate Flow Direction—Finds cells or a group of cells that flow into each other, creating a loop in a flow direction raster.
  • Evaluate Variable Influence for Predictions—Evaluates how variables influence predictions from a spatial statistics model file (.ssm).
  • Add Color Scheme—Adds a color scheme definition for features in a utility network's telecom domain network to identify fiber strands, cables, and connectors in telecommunication systems.
  • Add Color Set—Adds a color set to provide a standardized color library that can be consumed by color schemes in your network using the Add Color Scheme tool.
  • Add Telecom Domain Network—Adds a telecom domain network to a utility network.
  • Add Wavelength Scheme—Adds a wavelength scheme to a utility network's telecom domain network to support wavelength propagation.
  • Delete Color Scheme—Deletes a color scheme from a telecom domain network. Each color scheme includes a hierarchical definition with multiple levels. Each level has its own labels, capacities, and delimiters.
  • Export Circuits—Exports feature and connectivity information about the features and objects that compose circuits in a telecom domain network.
  • Export Circuit Definitions—Exports the contents of the circuit management tables from a telecom domain network for the specified component type.
  • Import Circuit Definitions—Imports circuit information from a series of .csv files into the circuit management tables of a telecom domain network.
  • Set Circuit Properties—Sets the properties for circuits in a telecom domain network when they are imported, traced, or exported.
  • Set Telecom Object Combine Policy—Sets the combine policy for grouped junction and edge objects in a telecom domain network to determine how attribute values will be handled during a combine operation.
  • Set Telecom Object Divide Policy—Sets the divide policy for grouped junction and edge objects in a telecom domain network to determine how attribute values will be handled during a divide operation.
  • Verify Circuits—Checks the validity of circuits in a telecom domain network after features associated with a circuit are modified.
Version history
Last update:
‎04-15-2025 02:57 PM
Updated by:
Contributors
