Add Google Maps to ArcMap and Pro
105739
12
04-23-2021 11:47 AM
AndresCastillo
16 12 105K
This article discusses adding a Tile Layer url to your portal, then accessing the portal item via ArcGIS Pro and ArcMap:
https://socalgis.org/2020/12/02/add-google-maps-to-arcmap-and-pro/#:~:text=Once%20logged%20in%2C%20o....
Here's some of the Google url's the article mentions:
Google Mapshttps://mt1.google.com/vt/lyrs=r&x={col}&y={row}&z={level}
Google Satellitehttp://www.google.cn/maps/vt?lyrs=s@189&gl=cn&x={col}&y={row}&z={level}
Google Satellite Hybridhttps://mt1.google.com/vt/lyrs=y&x={col}&y={row}&z={level}
Google Terrainhttps://mt1.google.com/vt/lyrs=p&x={col}&y={row}&z={level}
Google Roadshttps://mt1.google.com/vt/lyrs=h&x={col}&y={row}&z={level}
This article discusses exporting a small image of your desired area from Google Earth, then georeferencing it to view in ArcGIS Pro/ArcMap:
How To: Use Google Earth images as basemaps in ArcGIS Pro
https://support.esri.com/en/technical-article/000023334
Here's some other discussions on this online:
https://www.hatarilabs.com/ih-en/how-to-add-a-google-map-in-qgis-3-tutorial
https://stackoverflow.com/questions/23017766/google-maps-tile-url-for-hybrid-maptype-tiles
12 Comments
neomapper
Is this safe to use for an organization?
BushraYoussef
New Explorer
GregoryBondar
Observer
ESRI insists that URLs be from secure (https) websites. Is there an https link to use the Google Satellite images?
lvargas
Hello @GregoryBondar
In another post, I commented something similar.
Here is the list with the URLs, I have used them and so far they are working normally.
Services:
Google Roads Only
Google Standard Roadmap
https://mt1.google.com/vt/lyrs=m&x={col}&y={row}&z={level}
Google Altered Roadmap
Google Satellite
https://mt1.google.com/vt/lyrs=s&x={col}&y={row}&z={level
Google Terrain Only
https://mt1.google.com/vt/lyrs=t&x={col}&y={row}&z={level}
Google Terrain
Google Hybrid
You can use the Google Satellite url with https.
Regards.
mamaya_geotec
New Explorer
Hi
Google Maps API has usage policies that limit the number of requests you can make within a certain period of time. These policies vary depending on the type of API you're using (e.g., Maps JavaScript API, Maps Static API, etc.). If you make a very large number of requests, you may reach the limits of free usage and need to pay for a premium plan to access more requests.
Would this apply to this case?
Regards
VenessaMcCracken
Does anyone have a link to an add-in for ArcGIS Pro 3x for a tool that will open Google Maps when you click on a location in your Pro map window?
Calls
Hello, I am trying to add google's photorealistic 3d tiles to Scene, using ArcGIS Pro 3.30.
Photorealistic 3D Tiles  |  Google Maps Tile API  |  Google for Developers
This is the javascript api call -
https://tile.googleapis.com/v1/3dtiles/root.json?key=[YOUR API KEY]
Is this tileset supported? Is there a workaround to create a layer using ArcPy (or something else)?
Sean_Wray
@VenessaMcCracken  - right click on your map (see below) - then go to google maps and paste the result in the search.
FokhruddinBhuiyan
New Explorer
URL does not point to an ArcGIS server. problem showing
hoogw
Hi Guys , in 2025 I tried all of above googe map link is no longer working .
So you will need to use new google link
URL: http://mt0.google.com/vt/lyrs=y&hl=en&x={x}&y={y}&z={z}
URL: http://mt0.google.com/vt/lyrs=m&hl=en&x={x}&y={y}&z={z}
URL: http://mt0.google.com/vt/lyrs=p&hl=en&x={x}&y={y}&z={z}
NAME: GE Altered roadmap
URL: http://mt0.google.com/vt/lyrs=r&hl=en&x={x}&y={y}&z={z}
NAME: GE Satellite only
URL: http://mt0.google.com/vt/lyrs=s&hl=en&x={x}&y={y}&z={z}
NAME: GE Terrain only
URL: http://mt0.google.com/vt/lyrs=t&hl=en&x={x}&y={y}&z={z}
see my google map loaded with yellow point shape file
hoogw
install quick map service plugin, I can quickly add all google maps
wtfineberg
Regarding the question raised by @neomapper,
Does licensing allow Google Tile Servers to be used by an organization? I can only locate documentation and Terms of Service for using the API via an API key. I cannot locate documentation for these tile servers that are exposed publicly.
Any guidance regarding licensing would be greatly appreciated!
About the Author
I am really interested in Programming. GeoNet MVP.
