Traverse tool doesn't have option for DMS after update
3343
9
07-15-2022 07:08 AM
TravysBaker
Hello all,
After upgrading to pro 3.0 I'm unable to input a delta angle in DMS format. Using a lower case d after typing in a value like 27-10-28 to force it doesn't work either. Is this a bug/something simple I'm missing?  The only way I can input the delta's from maps is to convert all the DMS notation to decimal degree. See the screenshot below of what should be the notation selector box and is instead just units.
Changing my display options to default to DMS does this:
I enter the traverse and...
The delta angle ignores what I input and gives me 51-00-00.
Anyone have any clues as to what is afoot here? I'm mostly confused because this worked no problem last version!
This is what I get for not waiting until the first patch comes out...
Thanks!
AmirBar-Maor
Thanks for reporting.
This is indeed a bug in 3.0 that we have fixed.
We will try to get it as part of a 3.0 patch.
DanPatterson
MVP Esteemed Contributor
I haven't used them, but you can confirm the shortcuts to see if there has been a change in 3.0
Enter a traverse—ArcGIS Pro | Documentation
... sort of retired...
AmirBar-Maor
TravysBaker
Awesome, thanks for the heads up Amir
Eliot_Reid
Hi Amir, is there a bug number to track this or can you confirm if this is supposed to have been fixed? I've updated pro to the latest patch (3.0.3) and it's not fixed yet. Thanks.
AmirBar-Maor
@Eliot_Reid
The bug number is "BUG-000151086"
It has been fixed in ArcGIS Pro 3.1 but has not been ported to 3.0.x yet. I'll update this thread once we patch it in 3.0.
BillFox
MVP Notable Contributor
short answer:
Evanscounty
I just updated to 3.2.2 and it seems this bug is a "thing" again, I cannot find where to set to allow me to enter my traverse directions in DMS and QB, only QB option is DD, Ive set all units correctly in the options section of Pro, just started after getting 3.2.2 last week,
BillFox
Just for a quick visual reference, can you please post up a screen pic of your current Pro 3.2.2 > Options > Units page for Distance, Angular, Area, Location and Direction?
