Hello, happy October again!
Is there a way to use Transfer Attributes between a Pro COGO line feature class (works, auto-labels, etc) and the Parcels_Lines class that also has COGO enabled? So far, every time I run transfer attributes, it creates a duplicate set of the COGO fields Direction_1, Distance_1, etc...and populates those with the result of the attribute transfer, while the original cogo fields (which are the ones actually referred to by the COGO functionality) remain blank. Meanwhile the Fields view in my attribute table pane gets more and more crowded each time I run the tool...
I'm migrating polygons into a version 3 parcel fabric, using arcgis pro 2.6 - with the goal to script this all with arcpy, so a functioning arcpy command is just as good a solution as a recipe for getting the tool to work through the Geoprocessing pane.
Context: Following the workflow from the Append Data page in the Getting Started with Parcel Fabric guide, I select a group of polygons and append them to my Parcels polygon table. Then create records from a RecordName field, then build parcel fabric to add the points and lines. Finally transfer attributes to get the cogo values from my (existing & Pro) source cogo dataset into the new lines created by build pf. But even the Transfer Attributes help page says it tries to duplicate fields rather than populating the existing cogo fields 😕
Thanks for any and all help and pointers!
