Moving a fabric point no longer drags connected lines and polygons
3661
12
07-10-2023 02:53 PM
DrewDowling
For some reason when we move a Fabric point, it no longer drags connected line and polygon features with it. In the past, I know we have been able to drag a fabric point a few feet to make it align better with surrounding features and connected parcel types would move with it.
This is no longer happening. The point will move but the connected lines and polygons will stay where they were.
Rebuilding the fabric will create a new point back at the original location.
As a sanity check, I exported the data to a new fabric in a local FGDB and tried dragging the point again. This time it worked, connected lines were dragged with the fabric point.
jcarlson
MVP Alum
I often find that when I open a project with a parcel fabric in the map, I need to go to the Edit tab of the ribbon for it to recognize that there is an active topology. After that, the tools work as intended. Can you check out that tab to make sure the topology is active?
- Josh Carlson
Kendall County GIS
jcarlson
MVP Alum
- Josh Carlson
Kendall County GIS
DrewDowling
D'OH 🤦
jcarlson
MVP Alum
I wouldn't consider it a "d'oh" issue at all! With literally every other feature dataset I load with a topology, and even with projects that have an ad-hoc map topology turned on, the project remembers that the topology is active and does not require this.
It seems like a Fabric specific bug, where its topology needs a "reminder" to start acting right.
- Josh Carlson
Kendall County GIS
AmirBar-Maor
@DrewDowling @jcarlson
When you add a parcel fabric to a new map we set the correct default behavior = geodatabase topology.
If you close and open the map it does remember this setting.
If you know the steps that make the map 'forget' the setting we would love to know (and fix).
jcarlson
MVP Alum
The "steps":
  1. Close the project
  2. Open the project
To be clear, I don't actually have to change the setting to geodatabase topology, but until I visit the Edit tab, it behaves as though none is in place. Simply switching to the Edit tab seems to "remind" Pro that the topology is there.
- Josh Carlson
Kendall County GIS
AmirBar-Maor
@jcarlson
I am not able to reproduce the behavior you are seeing with ArcGIS Pro version 3.1 (and the future 3.2). 🤔
After opening the project, while on the Map tab, I use the Select tool to select a point, then right-click and use the Move tool. The 'rubber banding' indicates that the topology is on.
How do you determine that the topology is turned off?
Amir
jcarlson
MVP Alum
When using standard editing tools like "Edit Vertices", "Reshape", and the like, I am not presented with the "Edges" option.
- Josh Carlson
Kendall County GIS
jcarlson
MVP Alum
Oh and topology-specific tools like align edge are not selectable until I visit the Edit tab.
- Josh Carlson
Kendall County GIS
jcarlson
MVP Alum
@AmirBar-Maor  you'll be happy to know this behavior has disappeared. I was using the same Pro Project from previous versions, and I think it must have hung onto some setting, I'm not sure.
Adding the fabric to a brand new project, and it picks up the topology right away.
- Josh Carlson
Kendall County GIS
