Is merge points available in ArcGIS Pro 2.6?
3344
12
07-20-2020 12:11 PM
MARIUSGLOVACI
DanPatterson
There is a merge tool which can be used with point featureclasses, but by chance are you looking for
Aggregate Points—ArcGIS Pro | Documentation
... sort of retired...
MARIUSGLOVACI
I am looking for Merge Points in Parcel Fabric.
Let's say I have a lot corner and very close a Parcel Map corner and a tract map corner
At this location should be one point only and all the topological features lines and polygons should reflect this new point with updated point ID.
DanPatterson
I see no tool of that name, but you can confirm at the end of the month when Beta 2 ends
JoshuaBixby
Are you referring to the Mean Points tool in the Parcel Editor Toolbar in ArcGIS Desktop/ArcMap?  Are you looking for the equivalent in Pro?
MARIUSGLOVACI
The question is specific to Parcel Fabric and the answer from Amy Andis is the tool is going to be available in ArcGIS Pro 2.7
AmirBar-Maor
Hi Marius,
A new tool to Merge Parcel Fabric Points is coming out with Pro 2.7.
Please post any Pro Parcel Fabric related question/idea in the new parcel fabric place: https://community.esri.com/t5/arcgis-parcel-fabric/ct-p/arcgis-parcel-fabric
Amir
MARIUSGLOVACI
Hi Amir,
Is there any way to disable Checking ability to merge until the user selects the point to preserve?
AmirBar-Maor
Hi Marius,
Once you select the points one of them will be selected by default.
I think we try to make a smart choice which point that is, but that is not always possible.
Could you please describe your concern with the current behavior?
MARIUSGLOVACI
In my case 2.8 I can see Check ability to merge running for a long time.
Dennis gave me the idea to Cancel the window and choose my point, in order to improve the performance.
The smart choice in my case and I can see it in your case also is to select the point with lowest objectid as default.  you might consider choosing the point with the highest objectid as default because usually is coming from a newer survey and not from one where a surveyor who used a compass and a chain.
