Unable to IMPORT Shapefile to ArcGISOnline Maps
12975
30
04-24-2012 04:03 AM
TimothySmothers1
Have been attempting to import Shapefiles to an existing map in the product - it fails with any of the new ZIP's that I am attempting to load.  And even fails with old ZIP's that worked previously.  I have tried in IE8 and Chrome with the same message.  Chrome gives a larger report (see below)
Unable to import this shapefile. (Could not connect to net.tcp://10.115.184.119:20000/AnalyzerService. The connection attempt lasted for a time span of 00:00:20.9982528. TCP error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond 10.115.184.119:20000. )
My load is respecting the geography of the original data source.  Please advise if there is a problem with AGOL at this time for loading shapefiles.  This is a personal free account and not a Beta Application import.
Regards
Tim
MarkAnderson
I'm having this same issue.  I still have it whether I'm using Chrome incognito mode or Internet Explorer.  I am at my wits' end.
