Unable to add my content to my arcgis.com map
5425
22
05-27-2010 06:27 AM
SimonMorgan
I uploaded a package file that contained data from a fiel geodatabase. I made it public and available for everyone. When I try to add it to a map, I leave the search string blank and it does not find it, I tried searching by the tags I used and still nothing. Anyone had any luck adding layers fromt he my content portion of arcgis.com?
jcokin1
Just an FYI
The "My Contents" Feature for ArcGIS.com still does not work.
At the following site search "Creating Maps".
http://www.arcgis.com/help/help.htm
Under Adding layers it states "NOTE: Only ArcGIS Server map, image, and feature services can be added to the map. Other layer types, such as layer packages, are not supported at this time."
I hope they get this feature fixed soon.
LanceCase
Still not working as of 29Oct10?!  Seriously?  This was supposed to be a selling point...  (For shame.  Are you getting this ESRI?)
SusanMordy1
I am experiencing this problem as well.
I have a public map service:
http://maps.gov.bc.ca/arcserver/rest/services/eteam/eteam/MapServer/9
I just get a message that says "Loading..." for over 30 mins
See attached.
I am assuming any map service you add has to be in the same projection as the base (eg: Bing = Mercator)
Thanks for your help.
Susan
MikeMinami
Esri Notable Contributor
Susan,
Looks like you've encountered a bug, as the loading message should not be displaying when the URL is incorrect. The URL to your server you need to enter is this:
Then you should see the list of your services. You can add the eteam service as a whole. You can't add individual layers inside a service separately, however.
Mike
SusanMordy1
Thanks Mike...solved my problem....
jcokin1
Still no word as to this feature in ArcGIS.com (11/29/2010)
Unable to load data into the base map from the "My Contents" folder which contains layer packages.
Was this not one of the key selling points of the ArcGIS.com (ArcGIS Online) service when ESRI presented this at the 2010 User conference?
http://proceedings.esri.com/dvd/uc/2010/uc-index/uc/workshops/tw_669.pdf
I went back through the above PDF but it is not clear.
I looked through my notes from Bernie Szukalski's talk and I circled and highlighted about this specific feature as a great solution for those users who can not afford the huge cost of setting up an ArcGIS Server.
I hope ESRI follows up and lets us know the status of this feature ever working?
EvaWillerslev
Precisely! ESRI told us many times that ArcGIS Online was a great solution for those users who can not afford the huge cost of setting up an ArcGIS Server. It's just so annoying that it doesn't work without the ArcGIS Server! ESRI: please come on: when will it work as promised?
Eva Willerslev
Emaps http://emaps.dk
AndrewL
I am also having this problem where I cannot add data from my layer package. I would like to see a solution soon. Thank you.
JinLee
I am experiencing same problem here but non of Mike suggestions fix my problem.
am trying to add my arcgis server map service through add button to arcgis.com map viewer
but got "url does not point to arcgis server...." message.
url for my map services is
http://169.226.25.50/arcgis/rest/services
attachment screenshot has more detail.
any idea?
MikeMinami
Jin Lee,
What version of ArcGIS Server are you running? I suspect ArcGIS Server .NET v 9.3.1 with IIS.
I believe you've encountered a bug. The problem is you have a folder name that begins with a number. This causes the server to return some invalid information, and thus, arcgis.com can't connect to your server. You can either upgrade your server to the latest version, or simply try renaming your folder named 2005 so that it begins with a letter.
Mike
