Split Line ArcGIS Online
7282
6
04-19-2016 08:58 AM
jaykapalczynski
Honored Contributor
Is there a tool that will allow a user to split a line via ArcGIS Online app?  Anything out of the box or do I need to create my own JavaScript App?
jaykapalczynski
Honored Contributor
Looking to split a line in ArcGIS online app or a JavaScript app I would have to write.  Anything out of the box in AGO?
AdrianWelsh
MVP Honored Contributor
Hi Jay,
How are you wanting to 'split' this line? Are there certain criteria that you will need? Please give some more details.
jaykapalczynski
Honored Contributor
Nothing special....Either
  • A user specified point that is snapped to the line.  Once placed it splits the line in two.  Error alert if it does not land on a line
  • A user specified line intersecting the line to split.  Click once to start the splitting line, drag across a line to be split, click second time to stop.  Error alert if it does not cross a line to be split.
UPDATE:  Forgot to thank you for your reply....very appreciated.
AdrianWelsh
Interesting. I am not sure as I am not a strong developer.
I am tagging a few other spaces in order for this to get more visibility
DevelopersArcGIS API for JavaScriptWeb DevelopersWeb AppBuilder for ArcGIS
neiden
Did you ever figure out how to do this? Is there a Split Line tool available in ArcGiS Online?
KevinMayall
The Edit widget in Web App Builder has an option to display a Cut tool which will split a line.
Kevin
