Popup window does not show result of Arcade expression
1691
08-10-2017 04:43 PM
XanderBakker
Esri Esteemed Contributor
I have created a Web Map in ArcGIS Online containing polygons for solid waste collection and each polygon contains information of the days the truck collects in that zone and the time range wherein that happens. I thought it would be nice to create an Arcade expression that would show the next moment the truck passes in each area.
For some reason the result of the expression is not shown in the popup. The expression result appears blank for any selected polygon:
This should probably be caused by some error in the expression, but the weird thing is, that the test in the Arcade window does return a valid result:
I wrote some values to the console and in this case it used a polygon with frequency "WS" (Wednesday and Saturday = Miércoles y Sábado😞
So, why do I have a result for the test, but in the popup there is no result for the same polygon and attributes?
Below the setting for the popup window:
And the script I have so far:
// weekdays 0=DO, 1=LU, 2=MA, 3=MI, 4=JU, 5=VI, 6=SA
var dias = {'LJ': [1, 4], 'MV': [2, 5], 'WS': [3, 6], 'LWV': [1, 3, 5], 'MJS': [2, 4, 6], 'LaS': [1, 2, 3, 4, 5, 6]};
var horas = {'3PM A 7PM': [15, 19], '6AM a 10AM': [6, 10], '8AM a 12M.': [8, 12], '9PM a 1AM':[21, 24]};
var ahora = Now();
var hoy = Weekday(ahora);
var hora = Hour(ahora);
Console('hoy:' + hoy);
Console('hora:' + hora);
Console('Freq:'+$feature.FRECUENCIA);
Console('horario:'+$feature.HORARIO);
var lst_dias = dias[$feature.FRECUENCIA];
Console('lst_dias:' + lst_dias);
var lst_hora_minmax = horas[Upper($feature.HORARIO)];
Console('lst_hora_minmax:' + lst_hora_minmax);
var test = IndexOf(lst_dias, hoy)
Console('test:' + test);
var resultado = 'Not Set';
if (test != -1) {
    Console('hoy en lista')
    resultado = 'pasó hoy:' + $feature.HORARIO;
    hora_max = lst_hora_minmax[1];
    if (hora < hora_max) {
        resultado = 'viene hoy: ' + $feature.HORARIO;
} else {
    Console('hoy no en lista, buscar próximo día');
    // find next day
    var dia_min = lst_dias[0];
    Console('dia_min:' + dia_min);
    var i = 0;
    for (var a in lst_dias) {
        i++;
    Console('i:'+i);
    var dia_max = lst_dias[i-1];
    Console('dia_max:' + dia_max);
    if (hoy < dia_min) {
        Console('hoy < dia_min');
        var dif_days = dia_min - hoy;
        var next_day = DateAdd(Today(), dif_days, 'days');
    } else if (hoy > dia_max) {
        Console('hoy > dia_max');
        var dif_days = dia_min + 7 - hoy;
    } else {
        // entre min y max, pilas hay más de un elemento
        Console('hoy entre min y max');
        var dif_days = dia_max - hoy;
    Console(next_day);
    var mes = Month(next_day) + 1;
    resultado = Day(next_day) + "-" + mes + "-" + Year(next_day) + ' - ' + $feature.HORARIO;
return resultado;
It is still not finished, but it should give some result and I would expect that it would give me the same result as during the test in the Arcade expression editor.
Does anyone know what might be wrong with the expression or somewhere else?
CC: KGerrow-esristaff
https://community.esri.com/community/developers?sr=search&searchId=a4c7f5bd-4c33-4c15-864d-ff3a75503...
KellyGerrow
Esri Alum
Hey Xander Bakker‌,
I take no credit for this answer as some others researched and found the answer, but I'm happy to report the solution. There is an issue with the editor that caused the error not to be recognized, when the script was failing. The development team is going to work on this.
The hora_max variable was missing a declaration. Please see the highlighted script below:
var ahora = Now();
var lst_dias = dias[Upper($feature.FRECUENCIA)];
if (test != -1) {
    var hora_max = lst_hora_minmax[1];
} else {
    // find next day
    var i = 0;
        i++;
    console(i)
    } else {
return resultado;
Add the declaration, and let us know if it fixed the error.
-Kelly
KellyGerrow
Esri Alum
Hey xander_bakker‌,
Are you able to share your web map that you are working with?
-Kelly
XanderBakker
Hi Kelly Gerrow ,
I just shared the Web Map to the public. Here is the URL:
http://arcg.is/4yz81
Thanks in advance!
Kind regards, Xander
XanderBakker
This is the URL to the hosted features service:
https://services3.arcgis.com/wPe5k6dJ32ybQjvP/arcgis/rest/services/RecoleccionEMVARIAS/FeatureServer
The expression is applied to the third layer "Zonas Bloques"
KellyGerrow
Esri Alum
Hey Xander Bakker‌,
var ahora = Now();
if (test != -1) {
} else {
    // find next day
    var i = 0;
        i++;
    console(i)
    } else {
return resultado;
-Kelly
XanderBakker
Hi Kelly Gerrow  thanks a lot and please pass my gratitude to those that solved the issue in my code!
I will have to be more careful with those type of declarations. There are not required in Python where I spend most of my time scripting, so it will take some adjustment for me to get this right.
