Hello, I am having a problem where my pop-ups are displaying fine in web viewer, but when I open the map in FieldMaps they are not coming up. Has anyone experienced this? Any advice on what might be causing this issue?
Also running into this issue. Any updates? The issue is also present in Explorer.
We are using ArcGIS Enterprise 10.9.1
Map was created in classic map viewer. No custom pop-up elements.
The layer itself is part of a group layer and is referenced from our SDE published from ArcGIS Pro.
I was able to get them to work when saving a copy of the map in the new map viewer and toggling the pop-ups off and on again. Toggling the pop-up in map viewer classic did not resolve the problem.
Does anyone have a solution to this. I´m having the same problem and everything looks fine in web maps (both new viewer and classic). pop ups are enabled but if I try to access the pop up in field maps it won´t open but works fine otherwise. I had an arcade expression first that somehow disbaled my popup in fieldmaps. Fixed it and it worked for a couple of weeks and now it stopped working again and I can´t get the pop up to work for that layer. Not even if I clean the pop up. The service is from another portal instance that I don´t control, but everything looks fine and works fine, just not the pop up in fields maps.
I have this problem, only when offline. The popups work find in Field Maps when I have celular or WiFi on. When I turn those off, the popups do not work. Aren't they meant to?
