Offsetting Text labels for Line features in Map Viewer?
2551
08-31-2021 05:10 AM
JasonDeAbreu
I'm looking to offset my street name labels (line feature layer) in the new map viewer and I don't see any options to do that. Am I missing something or is that something that needs to be added down the road?
The old viewer gives you the option. Attached files.
Thanks for any help in advance.
Regards,
Jason
David_Brooks
MVP Regular Contributor
Unfortunately, not yet supported in Map Viewer, only Classic.
However, if you publish a Vector Tile Layer, then you'll have much more control over your labels, (above below, on, offset, even contour labels!)
David
..Maps with no limits..
JasonDeAbreu
Hey, thanks for the info. I've tried publishing the labels before and the shear amount of them it tends to crash or give me an error. I'll look into it a bit more now that you mention it.
Thanks again
David_Brooks
No problem. If the vector tile route works for you, then please mark as a solution for others to benefit 👍
David
