Hyperlink to another layer in a pop-up
1136
09-09-2020 07:25 AM
HelenCooper
Hi all,
I'm trying to work out if it's possible to hyperlink to another layer in AGOL?  I have a point layer, and I want to click on each point to see the catchment for that point, but I can't work out an elegant way of doing so.  Any guidance gratefully appreciated!
Helen
#agol #story maps classic
Tags (1)
Amber_Support
Esri Alum
Hello! I have found this documentation about configuring Pop Ups which has a section on Hyperlinks that might be a good place to start, you can find that here. There is a way to add a url to the pop up as a custom attribute display that could be useful, I also found this blog about the custom attribute display here
HelenCooper
Hi Amber, thank you very much for your reply.  It gets me half way there but doesn't quite resolve it.  I think I'd need to be able to create a URL to show exactly the tab on the story map and the layers I want to show, but I don't seem to be able to do this so far.
This helps with getting to the right tab: Launch a Story Map at a specific place , but can't work out how to view only specific layers and get the zoom level / extent as I'd need it to be.
