How to Allow Portal Layer Data to be Exported in AGOL
1094
02-23-2023 06:43 AM
StormwaterAdmin
Hello,
I have a hosted feature layer in Portal and created a layer in ArcGIS Online from it. I stored my credentials when I created the layer in ArcGIS Online. I also have the "Allow others to export" toggle on in the settings in Portal. I am still unable to see the export data option on the layer in ArcGIS online. Is there any way to fix this? I want to be able to allow users in my ArcGIS Online organization that don't have a Portal account to export the data.
Clubdebambos
MVP Regular Contributor
I put this question to ESRI before, and the outcome was that you could not export a Portal service from AGOL. To achieve this you can....
  • add to ArcGIS Pro and export.
  • use ArcPy to extract as various filetypes.
Not the answer I was hoping for or expecting. Very interested to hear if anything has changed and if it is possible to export directly from AGOL.
~ learn.finaldraftmapping.com
Clubdebambos
