How to Add Azure Maps as a Standalone Item in ArcGIS Online?
635
07-25-2025 07:06 AM
AustinOffice
I'm looking for a way to add Azure Maps as a standalone item in AGOL, so that it can be offered as a default base map for our organization — similar to how we previously used Bing Maps.
I have seen the blog post from ESRI (https://resources.esri.ca/getting-technical/integrating-microsoft-azure-maps-layers-into-your-arcgis) and the older Azure article (https://techcommunity.microsoft.com/discussions/azuremaps/using-azure-maps-in-arcgis-and-qgis/174496...) describing how to add Azure maps to a Pro project or to add directly to a web map in AGOL or Enterprise. These articles describe the same method and work fine. But there doesn't seem to be a way to add the tiled layer as its own item. I'd like to be able to share as a tiled layer across my organization so that users don't have to access the Azure maps subscription key directly.
I attempted to create a stand alone tile layer from the URL by manipulating the JSON with beta AGO Assistant, however I haven't been successful with this method. It appears web tile layers may not be a supported JSON type. I also attempted to add create a new item directly via the REST API. I can create the layer but I get warnings related to the x,y,z parameters of the URL string. AI suggests this is due to the format of the parameters as ?x=...&y=...&z=... rather than the standard {z}/{x}/{y} . I haven't been able to verify that this is the real issue.
Has anyone tried to do this and had success?
AustinOffice
I've solved my own problem. I'll post it here in case anyone else needs this solution in the future. It was a very straightforward fix, but one I wasn't familiar with. Once you have created a map with the azure imagery as a base map layer that map should be added to a group within AGOL. The group can then be set as the Basemap Gallery group within the Organization > Settings within the Map section. There's even an option to include ESRI default basemaps as part of the same group.
AustinOffice
