Edit related records table on ArcGIS Online
6285
10-31-2014 11:31 AM
Shai_V1
I can see related records of a feature on ArcGIS Online. I would like edit or add records to that related table. Is this functionality available now or is it an enhancement? If it is an enhancement, when is this going to be available?
Shai
RussRoberts
Esri Notable Contributor
You can edit records in ArcGIS Online when you show the result in the table in the map viewer or you can edit records on the item detail page under the Data tab. This is coming in Portal 10.5.1
NancyGnanicys
In version 10.3 it looks like you can edit related tables in Collector.
Collector for ArcGIS v10.3 is out and it’s a big deal!! | ArcGIS Blog
CharlieDoherty
Do we know if / when this is going to be available in ArcGIS Online/Portal?
We use ArcGIS Collector but the option to add and edit related records in ArcGIS Online and Portal would make things a lot easier and quicker for office based staff rather than having to load up Arcmap for a simple change.
If anyone can share any information on this that would be much appreciated.
Charlie
RussRoberts
deleted-user-2R8WoCwPoxOV
Do you have an estimated deployment time for this feature - having to reload the entire service to add one record to a layer is quite cumbersome!
