Change text displayed in ArcGIS Online Pop-Up with Arcade
2103
01-26-2023 11:07 AM
LaurenLumHee
I created an expression with Arcade to go to a hyperlink with a 7 digit code that pulls from a field.
My question is how do I change the Text for the hyperlink?
The default is 'View', but I'd like to display that 7 digit code from my field. I added this expression into the 'Fields List' in the pop-up configurations.
Apologies if this question has been answered. I'm very new to Arcade and most posts about hyperlinking from the Text option for Pop-Up content.
jcarlson
You'll want to add an Arcade element to your popup. This will give you the option to dynamically set HTML elements, and you can return something like this:
var id = left($feature.COA_Prop_ID, 7)
`<a href="https://www.collincad.org/propertysearch?prop_id=${id}">${id}</a>`
This will pipe in your ID to the link URL as well as the placeholder text.
- Josh Carlson
Kendall County GIS
LaurenLumHee
jcarlson
Don't put it in a field list. Your popup should let you add an Arcade element.
- Josh Carlson
Kendall County GIS
