Arcade to Display Text if Values Match
1004
07-28-2023 11:11 AM
Labels (2)
MelissaSalich
Since web map viewer in Portal does not support pop-ups for related tables yet, I'm trying to create a workaround with Arcade.
I want to label features based on if they have one of the three Global IDs from the related table.
Example:
If assignmenttype = {E4929F7E-B6D0-4DB9-8381-522FBAE6EE52} display the text "Hydrant Inspection"
if assignmenttype = {89FFDD54-95A3-41C8-B4A6-EEA3C18448F2} display the text "Valve Inspection"
if assignmenttype = {64A1361F-4B63-4949-B081-303D55F93346} display the text "Service Inspection"
What would be the best arcade function to configure?
Tags (1)
ArmstKP
@MelissaSalich You can definitely create an Arcade expression to show related records in the feature's popup.
You could also write an Arcade expression for symbology.  If there is a Hydrant Inspection, return this symbol.  If there is a Valve Inspection, return this symbol.  If there is both, return this symbol.....
KenBuja
MVP Esteemed Contributor
You can use the FeatureSetByRelationshipName function (if you're using Portal 10.8 or later) to get the related records for the feature.
var related = FeatureSetByRelationshipName($feature, "the relationship name");
var relatedRec = First(related);
return when (relatedRec.GlobalID == 'E4929F7E-B6D0-4DB9-8381-522FBAE6EE52', 'Hydrant Inspection',
      relatedRec.GlobalID == '89FFDD54-95A3-41C8-B4A6-EEA3C18448F2', 'Valve Inspection',
      relatedRec.GlobalID == '64A1361F-4B63-4949-B081-303D55F93346', 'Service Inspection',
      'No inspection')
 This example assumes there's only one related record for the feature.
MelissaSalich
thank you for the help, my dataset does not have a relationship.
