Arcade expression doesn't show in pop-up
1952
03-09-2022 01:46 PM
anonymous55
Hello,
I have this code and I getting result in test but I can't set it up in pop-up of new map viewer?
var intersectLayer =Top(OrderBy(FeatureSetByName($map,"xyz"),"Inspection_Date DES"), 3);
return intersectLayer
and this is I am seeing on pop-up
2 Solutions
JohannesLindner
intersectLayer is a FeatureSet. It will be shown in the expression builder's test, but popups can't show it.
You have to build a string:
var inspection_dates = []
for(var f in intersectLayer) {
    Push(inspection_dates, f.Inspection_Date)
return Concatenate(inspection_dates, TextFormatting.NewLine)
Have a great day!
Johannes
JohannesLindner
  • You're using Text() on a feature, which returns a json string containing info about the geometry and attributes of the feature. What you want to do is extracting the fields of the feature, not the whole feature.
  • You're not adding to your popupText sring. Instead you reassign a new value to it each time, which is why you only see one line as a result.
  • There's no need to call Text() here. Your fields are all strings, the number format won't do anything. What you could do is using DefaultValue() to insert some meaningful text if there's a null value in a field.
var popupLines = [
    "Age: " + DefaultValue(cou.age, "not reported"),
    "Gender: " + DefaultValue(cou.gender, "not reported"),
    "Race: " + DefaultValue(cou.race, "not reported"),
return Concatenate (popupLines, TextFormatting.NewLine)
// or comma sepated:
// return Concatenate(popupLines, ", ")
Have a great day!
Johannes
JohannesLindner
Have a great day!
Johannes
anonymous55
Hello
I have this code which bring different fields from another layer to pop up but I can't get the result on popup
var fips = $feature["parent_id"]
var dd = FeatureSetByName($map,
"Survey v2", ['age','gender','race'],False)
var fillterSur = "survey_id = @fips"
var cou = First(Filter(dd, fillterSur))
var popupTEXT = "Age: "
+Text(cou,'#,###')
var popupTEXT = "gender: "
+Text(cou,'#,###')
var popupTEXT = "race: "
+Text(cou,'#,###')
return popupTEXT
The result I am getting is like this :
JohannesLindner
var popupLines = [
Have a great day!
Johannes
