Hello, I have this code and I getting result in test but I can't set it up in pop-up of new map viewer?
var intersectLayer =Top(OrderBy(FeatureSetByName($map,"xyz"),"Inspection_Date DES"), 3); return intersectLayer
and this is I am seeing on pop-up
var popupLines = [ "Age: " + DefaultValue(cou.age, "not reported"), "Gender: " + DefaultValue(cou.gender, "not reported"), "Race: " + DefaultValue(cou.race, "not reported"), ] return Concatenate (popupLines, TextFormatting.NewLine) // or comma sepated: // return Concatenate(popupLines, ", ")
intersectLayer is a FeatureSet. It will be shown in the expression builder's test, but popups can't show it.
You have to build a string:
var inspection_dates = [] for(var f in intersectLayer) { Push(inspection_dates, f.Inspection_Date) } return Concatenate(inspection_dates, TextFormatting.NewLine)
Hello
I have this code which bring different fields from another layer to pop up but I can't get the result on popup
var fips = $feature["parent_id"] var dd = FeatureSetByName($map, "Survey v2", ['age','gender','race'],False) var fillterSur = "survey_id = @fips" var cou = First(Filter(dd, fillterSur)) var popupTEXT = "Age: " +Text(cou,'#,###') var popupTEXT = "gender: " +Text(cou,'#,###') var popupTEXT = "race: " +Text(cou,'#,###') return popupTEXT
The result I am getting is like this :
Signed in members can post, follow updates, and more. New here? Register a free account.
