How to get ArcSOCs used against each service Using ArcGIS Monitor 2023.2
137
a week ago
NaveenK
Is it possible to create an expression to get ArcSOCs in-use/used against each service on an ArcGIS Server Host. Can you please let me know how to achieve this?
DerekLaw
Esri Esteemed Contributor
Hi @NaveenK,
Please review this blog, 5 Useful ArcGIS Server Analysis Elements in ArcGIS Monitor
(please see element #3)
Hope this helps,
DerekLaw
Hi @NaveenK,
Hope this helps,
AndrewSakowicz
@NaveenK , to add to @DerekLaw , note the difference between
Metrics reference—ArcGIS Monitor | Documentation
Process instances, which is the number of arcsoc.exe running at the collection time (e.g. every 1 min):
and
ArcGIS Service Instances used, which is an average over collection interval, e.g. 5 min.
It is expected these numbers will be different.
NaveenK
Thank you.
