How to get ArcSOCs used against each service Using ArcGIS Monitor 2023.2
746
08-05-2024 07:19 AM
NaveenK
Is it possible to create an expression to get ArcSOCs in-use/used against each service on an ArcGIS Server Host. Can you please let me know how to achieve this?
DerekLaw
Esri Esteemed Contributor
Hi @NaveenK,
Please review this blog, 5 Useful ArcGIS Server Analysis Elements in ArcGIS Monitor
(please see element #3)
Hope this helps,
DerekLaw
Hi @NaveenK,
Hope this helps,
AndrewSakowicz
@NaveenK , to add to @DerekLaw , note the difference between
Metrics reference—ArcGIS Monitor | Documentation
Process instances, which is the number of arcsoc.exe running at the collection time (e.g. every 1 min):
and
ArcGIS Service Instances used, which is an average over collection interval, e.g. 5 min.
It is expected these numbers will be different.
NaveenK
Thank you.
SaurabhUpadhyaya
Hello Everyone,
I need guidance on ArcGIS Enterprise 11.1 capacity planning with Postgres RDS as the backend.
Scenario:
  • Services Published:
    1. Feature Service (Min Instances: 2, Max Instances: 5)
    2. Map Service
    3. Geoprocessing Service
  • Data:
    • ~2 million point features stored in Postgres RDS.
    • Each team will load ~2000 point features at a time through the ArcGIS JS API application.
  • Application Functionalities:
    • Load filtered point features per team.
    • Search and buffer operations.
    • Export to PDF.
Question:
How many concurrent users can a single ArcGIS Server support under this setup?
Would appreciate any insights on capacity planning and optimization strategies.
Thanks in advance!
