Error connecting to monitor database
3908
02-13-2023 02:23 PM
DanielHerrera
After setting up the agm database and user, I try to connect in the server setup dialog and get this error:
Knex: Timeout acquiring a connection. The pool is probably full. Are you missing a .transacting(trx) call?
GeoJosh
Hi Daniel,
Please try restarting both the ArcGIS Monitor and Postgres services and then running through the setup again.
Josh
GeoJosh
Hi Daniel,
Josh
DanielHerrera
Thank you Josh - that worked
MarkMaciolek
hi,
just installed it on Redhat Enterprise 8 and have same issue even after rebooting system.  Any other suggestions?
Mark
BHK
Re-starting both Database and Monitor fixed the issue on our side too, thanks
