AGM 2023.3: Connect Monitor Database Fails
1224
01-17-2024 08:46 AM
sempergumby
Hi all,
I have ArcGIS Monitor 2023.3 successfully installed on an ec2 instance in AWS. The managed database is hosted in an Aurora PostgreSQL RDS instance. During the initial configuration, in a attempting to connect to the PostgreSQL RDS instance, I get this error:
error: UPDATE metrics SET name = ARRAY_TO_STRING(ARRAY_PREPEND((select  name  from metrics_registry where r_id = base_r_id), (STRING_TO_ARRAY(r_id,':'))[2:]),' - ') - function array_prepend(character varying, text[]) does not exist
I am not sure how to troubleshoot this, but it is essentially preventing the configuration of ArcGIS Monitor.
Does anyone have any insight in this error or related  errors for initial configuration?
Thanks!
GeoJen
by Esri Contributor
Hi @sempergumby,
This should be resolved in the patch set to release at the end of this month. If your problem is not resolved when you upgrade your version of Monitor to 2023.3.1 please leave a comment here.
GeoJen
by Esri Contributor
Hi @sempergumby,
sempergumby
Thanks for the update!
sempergumby
Thanks again, as you outlined this issue was not encountered when we upgrade the ArcGIS Monitor  version 2023.3.1.
