ArcGIS Monitor and Setting up Oracle Client
2376
03-20-2018 02:50 PM
AlexStevenson
Hi All,
I've followed the Help documentation and downloaded/installed the Oracle Instant Client on the server hosting ArcGIS Monitor.  I now see a "Oracle in instantclient_12_2" entry in the Drivers tab when looking at the ODBC Data Source Administrator (64-bit).  However, when trying to test out an Oracle query in the Monitor Administrator, the test fails with a message of "Error: [Oracle][ODBC][Ora]ORA-12560: TNS:protocol adapter error".
I'm wondering if my Driver string is correct.  The syntax I have is as follows:
DRIVER={Oracle in instantclient_12_2};SERVER=oracleservername:1521/oracledatabase; UID=sdeusername; PWD=sdepassword
Any ideas?
Alex
JohnGraham2
Contact Esri Technical Support for help with the Driver string and connecting to the database.
ArcGIS Monitor and ArcGIS Server support the same versions of Oracle. So, Oracle 12.2.x would be supported: http://desktop.arcgis.com/en/arcmap/latest/manage-data/gdbs-in-oracle/database-requirements-oracle.h...
MichaelVolz
Esteemed Contributor
Does Monitor support Oracle 12.2.x?
JohnGraham2
lvargas
Hello,
I use Monitor 10.8.1 and Oracle Client 64x 12 (12.2.0.1.0), works with this connection string.
DRIVER={Oracle in OraClient12Home1};Dbq=TNSNAME; UID=sde; PWD=password
Regards.
