ArcGIS Monitor 2023.1 Upgrade Failure - There is a problem with this Windows Installer package custom action removeServerPassword script error
7604
27
05-04-2023 12:38 PM
AlexBakhtin
Hello everyone,
In attempting to upgrade Monitor 2023.0 to 2023.1, we ran into an issue where the installation would fail and then rollback the installation. Our first attempt in doing this caused our ArcGIS Monitor installation location to completely disappear save for three log files in ArcGIS/Monitor/bin/:
  • arcgis-monitor-server-service.err
  • arcgis-monitor-server-service.out
  • arcgis-monitor-server-service.wrapper
We managed to recover from a snapshot and get back up and running again. In trying to download the installer a second time, we checked the checksum and confirmed that it was correct however in trying to run through the upgrade, we were met with the same error again.
65BC35F7C463D731F690246B7FF95967D68030C3449A7793B05815F142FE7190
In looking in Event Viewer, we see the full message:
Product: ArcGIS Monitor 2023.1 -- Error 1720. There is a problem with this Windows Installer package. A script required for this install to complete could not be run. Contact your support personnel or package vendor. Custom action removeServerPassword script error -2146827864, Microsoft VBScript runtime error: Object required: 'WScript' Line 17, Column 1,
Not sure if anyone else is running into this issue with the latest installer but wanted to see if anyone else ran into issues upgrading.
Thanks.
Alex Bakhtin
BrandonCranfield
I was entering the password manually every time I was attempting to install
the application. That's interesting that you were able to get it to work,
though.
Mike_Tulis
Hello everyone. I am trying to install ArcGIS Monitor 2023.3 using gMSA and I am getting the same installation error 1772. I suspect it is related to the issue discussed here. Could someone please share with me the fix/workaround? Please and thank you.
DerekLaw
Esri Esteemed Contributor
Hi @Mike_Tulis,
I just replied back to your email regarding your post.
Hope it helps,
ChadCooperROK
This is still an issue at Monitor 2023.3.1, @DerekLaw. My domain-level service account has a single underscore in it, password has no special characters. I got this error:
My workaround was to install with a local account and password with no special characters, then post-install, in the Monitor Windows service, change the log on user to my domain account.
DerekLaw
Hi @ChadCooperROK,
This is still an issue at Monitor 2023.3.1 ...
Thanks for bringing this to my attention. I will ask the Dev team to check.
Best,
NicoleGamble1
Not related to the original issue but since installer error 1722 has also come up on this thread - if you are still seeing this when installing a more recent version of ArcGIS Monitor you may want to double check if the service account has permissions to it's own user profile, I have see this cause the same error as well.
The directories it needs permissions for are documented here:
https://doc.arcgis.com/en/monitor/latest/administration/windows/set-up-and-manage-an-arcgis-monitor-...
katelynjenk
Hello @DerekLaw and @GeoJosh I found this article as I have encountered the following error when installing the ArcGIS Monitor 2025.0.1 Agent to our Enterprise machine:
I install it through the gMSA account that runs ArcGIS Monitor Server and Agent on the Monitor VM. These work just fine.
I do not think it is BUG-000159608 since the Agent is successfully running under the same Service Account on a different machine. Perhaps I need to check something on our Enterprise machine regarding this gMSA? Any insight is appreciated. Again, this is a fresh install.
I run the installer as an Admin but wanted to circle back to this conversation on gMSA accounts and special characters? Thinking about logging a ticket with Esri Support but wanted to try here first.
GeoJosh
Hi @katelynjenk,
This is strange, I have not seen this behavior with the 2025.0.1 release. I think the best course of action is to log a case with Support to troubleshoot further. The fact that this is occurring on one machine but not others points to an environmental / configuration issue on the machine itself, which Support should be equipped to help narrow down.
Josh
