2024.1 ArcGIS Datastore Invalid Version: 11.3.0.51575
2473
19
01-30-2025 06:37 AM
Oiligriv
It's normal?
DavidColey
MVP Regular Contributor
I'm going to guess that datastore has to be at 11.4 to be a monitored component
ChrisTaylor2
I'm getting the same (for 11.1), but the documentation says it just needs to be 10.7.1 or higher.
Chris
EsriEvan
Hi folks,
Thank you all for reporting this. The team has been triaging it this morning and believe this issue is presenting specifically for ArcGIS Data Stores which were upgraded (for instance 11.1 ->11.4). Non-upgraded Data Stores do not seem to be affected. The team is working to address this and determine how best to deliver the fix.
Thanks!
DavidColey
I guess I had it backwards then with my reply.  But other than a fresh install of a datastore at any release, how could any datastore not be upgraded?
DavidJantz
Just another data point. I get the same error with version 10.9.1.28388 which has gone through upgrades.
DavidColey
Hmmm, ok. think I'm going to hold off on my upgrade from 2023.3.1 until this is resolved....
StevenBeothy
Just my 2¢:
I wouldn't have this one issue be the sole reason not to recommend anyone upgrade to AGM 2024.1.
#1. You're not losing functionality as registering the relational data store was just introduced at 2024.1.
#2. Consider the ArcGIS Monitor Life Cycle, with the release of 2024.1 all 2023.3.x releases are now in mature support and will be retired on Aug 27, 2025.
#3. Not to mention all the additional improvements at 2024.1 will out weigh the one ability not to register the data store until a patch is released.
DavidColey
yeah i was kinda rethinking that as well about an hour later.  I am definitely looking forward to the other enhancements, particularly the web adaptor as I'll be able to now get at monitor from outside the firewall.
KevinS
Also seeing this with 11.2.0.49116
That datastore was not upgraded from a previous version.
