Generate Depth Areas
4423
12
02-25-2021 08:03 PM
CBBiong
Hello everyone!
I've been trying to compile my ENC in ArcGIS Pro but since the Generate Depth Areas tool is not yet available, I tried opening my geodatabase in ArcMap and do the generation of depth areas there. For some reason, I can't generate any. There are no errors indicated but no features are created. I made sure that I covered the extent with land area and preliminary depth area, I also have my depth contours and soundings. Any leads where I went wrong? Thanks!
GuyNoll
Hi there!
In addition to the immediate challenge (ArcMap generate DEPARE), I think you may find this webinar recording of interest:  https://www.youtube.com/watch?v=OfqZfA493fY
Please email [email protected] for specific follow-up on this tool.
CraigTGreene
It might be easiest if you provided me a copy of your gdb. I think you have my email, or maybe your local Esri distributor can help you copy the gdb to a file share?
CraigTGreene
The Generate Depth Areas tool will be released in late October with ArcGIS Pro 2.9.
S6
by Esri Contributor
I am trying to create Depth Area using "Generate Depth Areas" from Point feature. Steps followed are:
1. Create TIN
2. Delineate TIN Data Area
3. Smooth Bathymetric TIN
4. Surface Contour
5. Generate Depth Areas
But the tool fails without any error message. Am I missing any step?
Can someone help?
CraigTGreene
If you are on the 3.0 release, you need to make sure that all features being used in the Generate Depth Area tool are in the same coordinate system. We have made a change in 3.0.2 that will allow you to use features with different coordinate systems.
S6
by Esri Contributor
Hi CraigTGreene,
Thank you for the reply. Yes, all the features are in same coordinate system - yet the tool fails. Any other parameter I should check?
CraigTGreene
It's difficult for me to say without seeing the data. Is it possible for you to provide the data so we can test?
S6
by Esri Contributor
Sure, sending you the sample in private message.
S6
by Esri Contributor
Did you get a chance to take a look at the sample data I shared?
Kind regards,
Saranya
