What's new in ArcGIS Maritime (Spring 2026)
Capabilities for producing nautical chart products with ArcGIS Maritime continue to grow with the release of ArcGIS Pro 3.7 and ArcGIS Enterprise 12.1. These releases feature new tools and enhancements that provide increased support for co-production, support for more S-100 standards, automated exchange set generation,…
how to use GIS tools for marien ,underwater
How to use GIS tools to create bathymetric contour management, violations, tin, sea floor, terrain production, and how it is different from surface management.
Data not visible after the upgrade from 11.1 to 11.5
Hey, recently we've upgraded from 11.1 to 11.5. Everything was done according to documentation. Senc files are regenerated, however nothing is being displayed in the service. ArcSOC of Maritime Service is running at 80-90% of cpu. Any tips? Regards, M.
How important is BIS metadata schema? Can it change?
Hi All! I am rebuilding my BIS using the ArcPro toolbox, and have run into an issue with the metadata schema template. Namely, If I select the BAG schema it wont let me add any other type of data. Is this a known limitation? If it is expected, is there a way to modify the current metadata schema so that I can add other…
What's new in ArcGIS Maritime (November 2025)
ArcGIS Maritime continues to expand and enhance its capabilities for managing and producing nautical products with the release of ArcGIS Maritime for ArcGIS Pro 3.6 and ArcGIS Maritime server for ArcGIS Enterprise 12.0. Work with exchange sets The biggest news for ArcGIS Maritime with this release is the introduction of…
maritime chart service for S-101
Does ArcGIS Maritime Server version 11.2 or above have the capability to create a maritime service directly from S-101 .000 data format, similar to how it works with S-57? https://enterprise.arcgis.com/en/maritime/11.2/chart-service/windows/managing-data-for-unencrypted-s-57-datasets.htm
Streamline S-100 Production with ArcGIS: Webinar Q&A
On October 7th, 2025, Esri experts Craig Greene and Paulina Karkauskaite demonstrated how to reduce the resource strain caused by the requirement to produce both S-57 and S-100 standard-compliant products for the next several years, until S-57 is fully retired. By leveraging ArcGIS to produce both S-101 and S-57 datasets…
Regarding the issue of inconsistent display between third-party software directly displaying nautical charts and using Pro/Server Charting.
Streamline S-100 Production - Upcoming Webinar Alert!
Streamline S-100 Production with ArcGIS Webinar October 7, 2025 | 7.30 a.m. pacific Be sure to register to attend or get the recording for our upcoming webinar where Esri experts will discuss streamlining S-100 production with ArcGIS. https://link.esri.com/S-100-Webinar/Registration-Co See you there!
Automating Paper Chart Production: Insights from Shom Webinar Recording and Q&A
Our recent webinar "Automating Paper Chart Production: Insights from Shom" explored the automation capabilities of the Custom Chart Builder (CCB) tool in ArcGIS Maritime. CCB is a web-based application that enables you to generate hard-copy navigational chart products in real time directly from the most up-to-date…
"Validation failed: ClusterRank failed to converge to a single point" error message
Hello everybody, launching the S-58 Error Manager tool in Maritime for Pro I receive this message: "Validation failed: ClusterRank failed to converge to a single point at (4.340027, 50.851848)". Looking at these coordinates there is nothing of unusual (a building): I've checked the geometry (that is correct), relaunched…
Generate Light Sector
Hello Everyone, I have question with Generate Light Sectors in Natical paper chart. When I run this function in the Chart Automation workflow, the results are different with run by separate tools, including: Generate Light Sector -> Apply Maritime Symbology. Is there any issue when setting parameters? Please find the…
Chart Automation
Hello everyone! I have a question regarding Paper Chart Creation using Chart Automation tool. Please see below workflow I did to understand main steps I should follow to create Paper Chart. My Questions: Q1. Do I need to create fresh FGD for local Paper Chart and import to it Paper Chart Schema? Q2. After creating FGD for…
How to extend the time dimension for the nautical database and extract an electronic chart at a specific moment in time series
I have already imported the data into the nautical dataset in accordance with the S57 standard.Now I want to add a time dimension to view the electronic chart at a particular moment. What should I do? Do I need to enable the time attribute for each object? Can the entire dataset be set up as a whole?
Problem with Generate Depth Areas and Generate Land Areas tools
Q1. Generating Depth Areas – Why the tool generates Depth Areas incorrectly? Q1 Comments: I populated all required feature classes: all polylines in DepthsL/DEPCNT_DepthContour snapped to AOI(Product Coverages), UNSARE and COALNE feature classes. DepthA/UNSARE_UnsurveyedArea has correct polygons with perfect topology with…
How to extract Sounding in ArcGIS Pro?
Hello, How can I extract soundings in ArcGIS Pro? In Bathymetry toolbox I only found Reduce Point Density tool which is very useful to work with soundings after extraction. In ArcMap I remember that Extract Depth and Reduce Point Density tools were located under Bathymetry toolbox. I couldn't find the similar tool in…
BIS alternative in ArcGIS Pro for generating contours and soundings for Chart Production
Hi everyone, Could anyone explain on higher level how to import all available raster datasets to sort of BIS db and generate compiled mosaic surface with ascending Survey Date order? I remember full workflow on older version of the ArcMap when I had dedicated GDB for BIS on SQL server.It was fairly straight forward process…
Can't find S-57 data model schema in ArcGIS installation directory
I am running ArcGIS ver 3.5.1 and I created local FileGeoDataBase. When I am trying to import XML Workspace for S-57 using this Wizzard: Copying a geodatabase using geodatabase XML workspaces—ArcGIS Pro | Documentation, I am unable to locate s-57 Schema in following installation directory: [C:\Program…
How to labeling the sounding in S101
I converted the 000 file of S57 standard to S101. As shown in the figure(left is s57,right is s101), the sounding have become multi-part point features according to the specifications. I want to know how to labeling them (just like the original S57). (I tried to extract the Z value of this multi-part point. But for each…
What's new in ArcGIS Maritime (May 2025)
ArcGIS Maritime includes tools to manage and visualize maritime data and produce nautical charts. These apps and tools get several enhancements with the release of ArcGIS Pro 3.5 and ArcGIS Enterprise 11.5. In ArcGIS Pro, there are several updates pertaining to the new Electronic Navigational Chart (ENC) standard, S-101,…
Assigning field values to DepthsA
Hello, I'm having trouble with the setting up the maritime geodatabase for the creation of S-57. This is something that I noticed after updating to ArcGIS 3.4, and I didn't bump into this error before that. I had a script that automatically sets the PLTS_COMP_SCALE to a user-defined value for Nautical/DepthsA. This script…
Features Cannot be created or Edited
I cant create any fatures or edit existng ones as it gives the error provided in the image below
S58 Error Manager Fail
S-58 Error Manager fails when trying to check for errors. Indicates that there is an error while processing
maritime Toolbox for ArcGis pro
I cant find the maritime toolbox anywherre in my installation folders, I would be grateful if someone could assist me with this. Also a beginner in ARCGIS maritime I would be grateful and open to any instruction manuals on how to create an S57 from scratch
Can’t create M_COVR for S57
I have trouble creating M_COVR for my s57 product. It keeps saying subtype doesn’t exist but I’m using the nautical Enc template for S57 ArcGis Pro 3.2 but I get this error
