Q1. Generating Depth Areas – Why the tool generates Depth Areas incorrectly?
Q1 Comments: I populated all required feature classes: all polylines in DepthsL/DEPCNT_DepthContour snapped to AOI(Product Coverages), UNSARE and COALNE feature classes. DepthA/UNSARE_UnsurveyedArea has correct polygons with perfect topology with CoastlineL/COALNE_Coastline and CoastlineL/SLCONS_ShorelineConstruction. Also, I added, polygons for Lakes (NaturalFeaturesA/LAKARE_Lake). For some reason I can not complete this simple task properly in ArcGIS ver 3.4.3.
Q2. Generating Land Areas – Why the tool generates Land Areas incorrectly? My problem after running tool: I am ending up with gap in LandAreas polygon (NaturalFeaturesA/ LNDARE_LandArea) between “Contour line 0 m” and “Contour line 50 m”.
Q2 Comments: I added features to following feature classes: NaturalFeaturesL/LNDELV_LandElevation (50 m interval elevation contour lines and I manually traced CoastlineL/COALNE_Coastline feature class to add 0 m elevation contour line). Moreover, I added polylines to NaturalFeaturesL/LNDARE_LandArea. Lastly, this tool also make Lakes as LandAreas which is complete nonsense for me.
PS: Please have a look at the attached GDB for testing. I would highly appreciate If anyone can help me to point at my problems with explicit comments and recommendations how to resolve it.
Hypothetical Question: If raster has so called "Raster Holidays" or Gaps is it affect Generate Depth Areas tool? I have attached TIN for reproducing the error. TIN in Positive UP values and I tried multiple combinations of SoundingsP and DepthL in Positive Up as well. It did not work out.
OS:
Edition Windows 10 Enterprise
Version 22H2
Installed on 2025-06-25
OS build 19045.5965
Experience Windows Feature Experience Pack 1000.19061.1000.0
Software:
ArcGIS Pro 3.4.3
