3D Object Scenelayer
1250
02-03-2023 08:37 AM
RupaLNU
Hi all,
I'm trying to work on bringing data from ArcGIS to Unity using ArcGIS Maps SDK for Unity with C#. I have followed all the instructions on the website https://developers.arcgis.com/unity/maps/tutorials/display-a-map-api/.
The problem is my 3D object scene layer in Unity is below the ArcGIS map and the image tile is also not loading in Unity. Can someone help please? I'm not sure where I'm doing it wrong.
Thanks
and1
by Esri Contributor
Hello, I couldn't reproduce the issue you mentioned. Did this happen in the play mode also? I would also double check with the camera position and those values for the origin position.
  • Longitude: -74.054921;
  • Latitude: 40.691242;
  • Altitude: 3000;
  • Spatial Reference WKID (Well-Known ID): 4326 (WGS84)
If possible, could you kindly provide a video of when the issue is reproduced?
