ArcGIS Maps for Adobe CC Questions
120
3.5M
215
| Needs Clarification | When I export labels for a curved line feature, for instance a river, road, or trail, from Pro to .aix, they export a... by FourCornersMapping Frequent Contributor 0 2 | 0 | 2 | |
| Open | I know the Legacy mapping profiles have been officially retired, but the layer organization was just so much nicer an... by vshelley Emerging Contributor 6 0 | 6 | 0 | |
| Open | It's been a while since I've tried this extension so I thought I'd check it out and see if it works yet. It doesn't s... by wayfaringrob Honored Contributor 0 2 | 0 | 2 | |
| Open | I am posting this to express interest in a documents board for the ArcGIS Maps for CC community. There is little docu... by JamesPoeschel Frequent Contributor 1 2 | 1 | 2 | |
| Open | Hello Anna, Yes, this was more of a UI question/request. I feel it would be beneficial to be able to read the error m... by LRSmith Occasional Contributor 2 0 | 2 | 0 | |
| Under Consideration | Is it possible to work with 3D layers in ArcGIS Maps for Adobe CC? When I export a 3D map to aix, the layout comes in... by GraceTortorici_ Regular Contributor 1 2 | 1 | 2 | |
| Open | I really like the ability of Pro to Export to AIX as it preserves the layer settings and is a lot easier to work with... by mcparkstrails Emerging Contributor 6 0 | 6 | 0 | |
| Open | Currently it seems that rasters export without an alpha channel -- they maintain a similar look, but their opacity is... by wayfaringrob Honored Contributor 2 1 | 2 | 1 | |
| Under Consideration | I use halos on nearly every map I make. When exporting a map with haloed text, though, they always look something lik... by wayfaringrob Honored Contributor 2 24 | 2 | 24 | |
| Open | It would be ideal to have grids and graticules built-in rather than having to get them from another source. Could the... by AletheaSteingisser Emerging Contributor 0 0 | 0 | 0 | |
| Open | We would like to create scale bars that are adjustable in measurement, and also have graphic styles to choose from. T... by AletheaSteingisser Emerging Contributor 3 0 | 3 | 0 | |
| Open | When I export an Illustrator file (.AIX) from ArcGIS Pro on a Windows machine, I would like to open that file in Illu... by FrancisHourigan1 Frequent Contributor 3 3 | 3 | 3 | |
| Open | Hi! Is it possible using Illustrator and the complimentary version of arcgis to draw a regional map and then add a gr... by melodycook Emerging Contributor 1 0 | 1 | 0 | |
| Open | Instead of creating a separate element for text outline, use the appearance panel to create a bottom stroke layer tha... by Anonymous User Not applicable 0 0 | 0 | 0 | |
| Implemented | Currently, one has to manually select features and re-apply each blend mode once in Illustrator to achieve the same e... by wayfaringrob Honored Contributor 0 7 | 0 | 7 |
Idea Submission Guidelines
