Using new measurement widget
13180
25
07-14-2014 11:43 AM
StevenGraf1
I see they added the ability to determine the xy locations for other coordinate systems, such as UTM, USNG, etc.  When I add the param
advancedLocationUnits:true
var measurement = new Measurement({
    map: map,
    defaultAreaUnit: Units.SQUARE_MILES,
    defaultLengthUnit: Units.KILOMETERS
  }, dom.byId('measurement'));
it adds the new units to the drop down but when I click on the map it doesn't return any thing.  I was just playing in the sandbox for the measurement samples.  Is there something else you need to add to return those projected coordinates?
JeffPace
Looks like you guys stole my style
A quick question.  The measure-end event only fires when you click on a location, but the Location updates on mousemove.  Is there anyway to fire a location-change event?
JonathanUihlein
Not officially, but I can look into getting that implemented for the next release.
You can create one for yourself in the meantime if you'd like with the following snippet:
aspect.after(measurement, "_outputLocationResult", function(args1, args2, args3){
  var values = measurement._calculateValueToDisplay(args1, args2, args3);
  console.log("values: ", values, args3);
}, true);
aspect.before(measurement, "_switchLocationUnit", function(){
  if(measurement.mouseMoveMapHandler){
    measurement.mouseMoveMapHandler.remove();
}, true),
The first aspect acts as your event listener. It fires when the mouse coordinates are updated in the widget's interface.
The second aspect fixes a bug introduced by implementing the first aspect (basically, the mouse handler never gets disconnected).
Full code:
<!DOCTYPE html>
<html>
<head>
  <meta http-equiv="X-UA-Compatible" content="IE=7,IE=9">
  <meta name="viewport" content="initial-scale=1, maximum-scale=1, user-scalable=no">
  <title>Move</title>
  <link rel="stylesheet" href="http://js.arcgis.com/3.10/js/dojo/dijit/themes/claro/claro.css">
  <link rel="stylesheet" href="http://js.arcgis.com/3.10/js/esri/css/esri.css">
  <style>
    html,body {
      height:100%;
      width:100%;
      margin:0;
    body {
      background-color:#FFF;
      overflow:hidden;
      font-family:"Trebuchet MS";
    #titlePane{
      width:240px;
    .claro .dijitTitlePaneTitle {
      background: #808775;
      font-weight:600;
      border:solid 1px #29201A;
    .claro .dijitTitlePaneTitleHover {
      background:#808775;
    .claro .dijitTitlePaneTitleActive {
      background:#808775;
    .claro .dijitTitlePaneContentOuter {
      border-right: solid 2px #808775 !important;
      border-bottom: solid 2px #808775 !important;
      border-left: solid 2px #808775 !important;
  </style>
  <script src="http://js.arcgis.com/3.10/"></script>
  <script>
    var map;
    require([
      "dojo/aspect",
      "dojo/ready",
      "esri/map",
      "dojo/parser",
      "dojo/dom",
      "esri/dijit/Measurement",
      "dijit/layout/BorderContainer",
      "dijit/layout/ContentPane",
      "dijit/TitlePane"
    ], function(
      aspect,
      ready,
      Map,
      parser,
      dom,
      Measurement,
      BorderContainer,
      ContentPane,
      TitlePane
      ready(function(){
        parser.parse();
        map = new Map("map", {
          basemap: "satellite",
          center: [-85.743, 38.256],
          zoom: 17
          map: map,
        }, "measurementDiv");
        measurement.startup();
        }, true),
        }, true);
  </script>
</head>
<body class="claro">
    <div id="mainWindow" data-dojo-type="dijit.layout.BorderContainer" data-dojo-props="design:'headline',gutters:false" style="width:100%; height:100%;">
      <div id="map" data-dojo-type="dijit.layout.ContentPane" data-dojo-props="region:'center'">
        <div style="position:absolute; right:20px; top:10px; z-Index:999;">
          <div id="titlePane" data-dojo-type="dijit.TitlePane" data-dojo-props="title:'Measurement', closable:'false', open:'false'">
            <div id="measurementDiv"></div>
            <span style="font-size:smaller;padding:5px 5px;">Press <b>CTRL</b> to enable snapping.</span>
          </div>
        </div>
      </div>
    </div>
</body>
</html>
AdrianMarsden
Honored Contributor
Jonathan
Any chance this is linked to my other issue BUG: Measurement widget measure-end event issue.‌ - So far un-commented on?
Cheers
ACM
JeffPace
Jon, this works perfectly!!!!
thank you so much.
Now, is there a secret "on tool change" type logic?
JonathanUihlein
aspect.after(measurement, "setTool", function(toolName){
  if(measurement.activeTool){
    console.log(toolName + " tool opened.");
  }else{
    console.log(toolName + " tool closed.");
}, true);
Note: this is mostly for identifying when a tool is opened.
However, there is an issue when using the 'Location' tool with this snippet.
This event will fire, even though the tool has clearly not changed (it is resetting certain widget properties using setTool() internally). This is a behind the scenes issue which I would like to fix.
You can work around this issue with the following (it removes the rogue setTool() call in the widget's _measureLocationClickHandler private function) :
  }else{
}, true);
aspect.before(measurement, "_measureLocationClickHandler", function(args1){
  measurement.locationToggleButton = null;
  measurement.locationToggleButton = function(){
    measurement.clearResult();
}, true);
aspect.after(measurement, "_measureLocationClickHandler", function(args1){
    measurement.setTool("location");
}, true);
KenCarrier
Jeff would you be willing to share your code, I am trying to do the same thing you are doing in your screen shot, thanks!
