Using new measurement widget
13042
25
07-14-2014 11:43 AM
StevenGraf1
I see they added the ability to determine the xy locations for other coordinate systems, such as UTM, USNG, etc.  When I add the param
advancedLocationUnits:true
var measurement = new Measurement({
    map: map,
    defaultAreaUnit: Units.SQUARE_MILES,
    defaultLengthUnit: Units.KILOMETERS
  }, dom.byId('measurement'));
it adds the new units to the drop down but when I click on the map it doesn't return any thing.  I was just playing in the sandbox for the measurement samples.  Is there something else you need to add to return those projected coordinates?
JonathanUihlein
What version of the geometry service are you using?
Your geometry service must be 10.2 or newer.
The sandbox sample of the Measurement widget is using an older version of the GeometryService (10.04).
http://tasks.arcgisonline.com/ArcGIS/rest/services
RamonCampos
Mine is 10.11.
Thank you for the feedback.
StevenGraf1
We are using 10.2.2
JonathanUihlein
Steven, thanks for your reply
If you go directly to your GeometryService and look under "Supported Operations", do you see toGeocoordinateString and fromGeocoordinateString?
For example, looking at the GeometryService used in the sample, we can see that these operations do not exist:
Geometry (GeometryServer)
StevenGraf1
I do not show those operations.  I assumed they were enabled when we upgraded to 10.2.2.  How do I enable them?  I'm not seeing a way to modify what operations are supported in geometry service though my server manager.
StevenGraf1
It also appear that the to GeoCoordinateString help link is broken.  I'm trying to access it through this link ArcGIS REST API
AdrianMarsden
Honored Contributor
So, having established that the  service hasn't got them,  How do we add them?
ScottDavis
Jonathan Uihlein - I don't see those operations at 10.2.1 or 10.2.2 in my geometry services. How do I get them?
Also, please update the docs for the measurement widget to explain the minimum server requirements.
Thanks!
BjornSvensson
Esri Alum
Scott Davis
The geometry service fromGeocoordinateString/toGeocoordinateString requires 10.3.
The doc has been https://developers.arcgis.com/javascript/jsapi/measurement-amd.html#measurement1-advancedlocationuni... (as of yesterdays 3.11 release) to reflect this.
ScottDavis
Yes, I saw that. Thanks for updating the doc. Hopeful that 10.3 is close to
release.
