Using $arcgis.import() with self hosted SDK
228
a month ago
NicolasGIS
Honored Contributor
In my organization, I can't use the CDN for data privacy reasons.
I need to download the SDK and host it.
I like the coding style offered by $arcgis.import() rather than using AMD and find it really convenient but I found out that it is not defined in the SDK downloaded:
https://developers.arcgis.com/javascript/latest/sdk-downloads-and-archive/
It's true that it is always refereed that is it only available for application built with the CDN so I guess it is by design but I was wondering why not making it available there as well ?
More info on the official blog post: https://www.esri.com/arcgis-blog/products/js-api-arcgis/developers/future-proof-your-arcgis-javascri...
Thanks for listening !
Nicolas
ReneRubalcava
Esri Frequent Contributor
The download of the SDK should be the same as what is published to the CDN.
Test this out locally and was able to use $arcgis.import()
<html lang="en">
<head>
  <meta charset="utf-8" />
  <meta name="viewport" content="initial-scale=1,maximum-scale=1,user-scalable=no" />
  <title>
    Test app
  </title>
  <link rel="stylesheet"
    href="http://localhost/builds/arcgis_js_v50_core_api/javascript/5.0/esri/themes/light/main.css" />
  <script type="module" src="http://localhost/builds/arcgis_js_v50_core_api/javascript/5.0/core.js"></script>
  <style>
    html,
    body,
    #viewDiv {
      padding: 0;
      margin: 0;
      height: 100%;
      width: 100%;
  </style>
  <script type="module">
    const [Map, MapView, Search] =
      await $arcgis.import([
        "@arcgis/core/Map.js",
        "@arcgis/core/views/MapView.js",
        "@arcgis/core/widgets/Search.js",
    const map = new Map({
      basemap: "dark-gray-vector",
    const view = new MapView({
      container: "viewDiv",
      map: map,
    const search = new Search({
      view: view,
    view.ui.add(search, "top-right");
  </script>
</head>
<body>
  <div id="viewDiv"></div>
</body>
</html>
Only place it's not available is in the npm build.
ReneRubalcava
<html lang="en">
<head>
  <title>
    Test app
  </title>
  <style>
    html,
    body,
    #viewDiv {
      padding: 0;
      margin: 0;
      height: 100%;
      width: 100%;
  </style>
      map: map,
      view: view,
  </script>
</head>
<body>
</body>
</html>
NicolasGIS
Honored Contributor
Thanks for your quick reply @ReneRubalcava !
Happy to read it is possible ! I must have done something wrong in my setup then. My bad. I had $arcgis.import error though everything seemed loaded at first sight. Will try again and let you know.
By the way, it would be great to have a simple export button with all the components and core wired properly for a given SDK version. Downloading everything manually from npm is error prone !
NicolasGIS
Honored Contributor
All good @ReneRubalcava  ! It works. Many thanks once again. Really happy to be able to leverage this functionnality.
