ArcGIS map-components Editor: hideFlow/visibleElements.flow missing in 5.x - how to hide the Back button?
299
06-22-2026 12:56 PM
EricErtl
Hi Esri community,
I am using ArcGIS Maps SDK for JavaScript map components in a React app and I am trying to hide the Back button in the Editor UI during an update workflow.
My setup:
  • ArcGIS packages: @ArcGIS/core 5.0.16 and @ArcGIS/map-components 5.0.16
  • Component: arcgis-editor
  • Workflow: I open popup action Edit, then call startUpdateWorkflowAtFeatureEdit(selectedFeature)
What I am seeing:
  • In older widget-based code, I used visibleElements.flow = false (or hideFlow in older examples) to remove the flow/back UI.
  • In arcgis-editor (map component), hideFlow is not available.
  • visibleElements is also not exposed as a public component property.
  • EditorViewModel does not appear to support visibleElements.flow either.
What I need:
  • A supported way to hide the Back button/flow UI in arcgis-editor.
  • If not supported, a recommended workaround that is stable for production.
Additional context:
  • I can still cancel workflows programmatically and collapse my side panel, but I specifically want to prevent users from using the built-in Back navigation in the Editor component.
Question:
Is there an official/supported replacement for hideFlow when using arcgis-editor in 5.x map components?
If not, what workaround do you recommend?
Thanks!
Noah-Sager
I think VisibleElements is now it's own class in the core API as of 5.0:
https://developers.arcgis.com/javascript/latest/references/core/widgets/Editor/VisibleElements/
You should be able to import this class and modify the visibleElements in the JavaScript code (not in the component).
EricErtl
Thanks for the reply @Noah-Sager.  Aren't all widgets being deprecated?  Do you have an example of using visibleElements in the JavaScript code and not using it in the component?
I may add this as an idea for the JavaScript SDK roadmap since this is a workflow that I need for most of my applications that allow for user editing.
