Typescript error adding sublayers to MapImageLayer
1677
02-22-2023 06:48 PM
LefterisKoumis
I declare a mapimagelayer
 const MPl = new MapImageLayer({
Then I created an array of sublayers that need to be visilbe.
 I added the sublayers index in an array
thearr.push({
            visible: true},
            visible: true}
Then, I used:
MPl.sublayers = thearr;
 but I got an  error
When I used this script without using typescript i have no errors and it runs fine.
Noah-Sager
I'm not 100% positive, but I think that if you don't declare the sublayers in the MapImageLayer constructor, you need to use one of the Collection methods to define/add/modify the sublayers.
Collection methods:
https://developers.arcgis.com/javascript/latest/api-reference/esri-core-Collection.html#methods-summ...
sublayers property:
https://developers.arcgis.com/javascript/latest/api-reference/esri-layers-MapImageLayer.html#sublaye...
Noah-Sager
Collection methods:
sublayers property:
LefterisKoumis
Thank you. Looking at the documentation, it seems that in JS 4.x is more work  to define visible layers of a mapimagelayer. In JS 3.x  we could just write this.
lyr.setVisibleLayers([1,2,3])
I assume there is  no similar way of doing so in JS 4.x
In a collection like
MPl.sublayers.push(item)
where item or comma-separated list of items cannot be the sublayer id.
Noah-Sager
Yes, there is an implementation difference between 3x and 4x. I would highly recommend looking at some 4x samples to get a feel for the difference. These two might be useful:
https://developers.arcgis.com/javascript/latest/sample-code/sandbox/?sample=layers-mapimagelayer-sub...
https://developers.arcgis.com/javascript/latest/sample-code/sandbox/?sample=layers-mapimagelayer-def...
